Woofri kast
    Woofri kast
    Ma tahaksin teha Woofri kasti sellisele bassikale.http://www.tevalo.ee/cgi-bin/web_sto...0.html&lng=est
    Nägin et keegi soovitas siin mingit proge millega saab kasti mõõdud kindlaks teha, aga proge on nii meeletu et midagi aru ei saanud.Äkki keegi vilunum saaks seda ise teha ja siia riputada.
    Driver Properties
    Type: Standard one-way driver
    Company: Visaton GmbH & Co.
    Serial No: 4720
    No. of Drivers = 1
    Fs = 43, Hz
    Qms = 3,51
    Vas = 49, liters
    Mms = 18, g
    Xmax = 3, mm
    Xmech = 10, mm
    Sd = 211, sq.cm
    Qes = 0,69
    Re = 3,6 ohms
    Le = 0,55 mH
    Z = 4, ohms
    BL = 4,98 Tm
    Pe = 80, watts
    Qts = 0,58
    1-W SPL = 87, dB
    Box Properties
    Name:
    Type: Closed Box
    Shape: Prism, square (optimum)
    Vb = 25,69 liters
    Qtc = 0,707
    QL = 6,994
    F3 = 68,07 Hz
    Fill = heavy
    Box Parts (Optimum Square Prism)
    1 Top, 1 Bottom: 22,35 © x 33,69 (B) cm
    2, (thick) cm
    1 Front, 1 Back: 48,05 (a) x 29,69 (d) cm
    2, (thick) cm
    2 Sides: 48,05 (a) x 22,35 © x 2, (thick) cm
    KES SOOVIB, SEE PROOVIB
    t-linespeakers.org
