mul on olemas s90 bassid..ja tahaks teha subwoofrit nendest (1 kõll kastikoha), inventeriga, aga ei oska kudagi kasti välja arvutada ???
Andmed:
Sd: 330.00 cm^2
Vas: 63.77 l
Cms: 4.18e-04 m/N
Cas: 4.56e-07 m^5/N
Mmd: 52.88 g
Mms: 56.27 g
Rms: 1.84 Ns/m
Fs: 32.8 Hz
Bl: 7.92 N/A
Re: 3.35 ohm
Le: 0.26 mH
Qms: 6.31
Qes: 0.62
Qts: 0.56
Pmax: 30.0 W
Xmax: 12.00 mm
h: 8.50 mm
l: 20.50 mm
Andmed:
Sd: 330.00 cm^2
Vas: 63.77 l
Cms: 4.18e-04 m/N
Cas: 4.56e-07 m^5/N
Mmd: 52.88 g
Mms: 56.27 g
Rms: 1.84 Ns/m
Fs: 32.8 Hz
Bl: 7.92 N/A
Re: 3.35 ohm
Le: 0.26 mH
Qms: 6.31
Qes: 0.62
Qts: 0.56
Pmax: 30.0 W
Xmax: 12.00 mm
h: 8.50 mm
l: 20.50 mm
