Millest alustada (võim + kõlarid)
    Tere
    Probleem lihtne ja selge.
    sooviks tekitada koju väikese helisüsteemi.
    1.Millest peaks alustama, mida enne juppide valimist tähele panna (toa eripära ? suurus ?)
    2.Millised võimalused/hinnad erinevatel lahendustel on ? (4kõlar+bass, 2kõlar+bass, lihtsalt 2 kõlarit, nendele erinevad võimud)
    3.Mis summadega tuleks arvestada ?
    Kas tavalise teleri taha ja tavalise cd mängija/arvuti taha on mõtet hakata mitme kanalist asja panema ?
    Kõigilt palun mõistvat suhtumist kui väga labaseid või lolle küsimusi esitasin.
    Ette tänades.
    How to buy a stereo
    1. Carefully calculate power requirements, based on room dimensions, etc. Multiply by a factor of 100.
    2. The ideal system should have as many lights as possible, preferably blinking and flashing in time with the music.
    3. The components should all have black metal finish, and generally look very C00L.
    4. The system should be broken up into as many components as possible. (e.g. pre-amp, pre-pre-amp, post-amp, etc.)
    5. The most important part of a stereo system is the speakers, they should look very cool. Size and number of sub-speakers is important. (e.g. woofers, seismic noise generators, hooters, tweeters, sub-woofers, super-sub-woofers, etc.)
    6. The system should resemble the cockpit of an F16 or 757 aircraft.
    7. The system should have full remote control capability, including over the mobile auto cellular phone so that the stereo can be playing as you get home.
    8. Should have the capability of playing different music in every room of the house.
    9. Components should have a cool names. ; this means no department store brands.
    10. The complete set up should put a major recording studio or large radio station to shame.
    11. Having state of the art equiptment is not enough. You should be a year or two ahead of everyone else. Equipment over the warranty period is obsolete and should be disposed of promptly.
    12 The most important factor...  Out of everyone you know who owns stereo equipment, yours should be better.
    Paintball Ruhnu saarel - http://www.combat.ee
    Ruhnu WiFi, PMR446, SATnet - http://ruhnu.combat.ee
      ;D ;D ;D
      Lisaks veel juure, et igale komponendile peaks peale kirjutatud olema vähemalt 2x 250W!
      Tõsisemalt ka: Mina ise alustasin kolmeribalise põrandakõlari ehitusest, kui need valmis, hakkan võimu otsima ja peale seda teen ise supaka.
      Mõni leiab kuskilt tolmuse vene valjuka ja hakkab selle ümber helisüsteemi ehitama.
      Alustuseks soovitaks S90 kõllid ja mingi vanem vene-läti võim, saad 1200 eegu eest päris hea heli tuppa.
        ülal oleva jutu järgi peab kõik olema COOL.. :-/ ple ju vaja et kõik välimuselt cool olex peaasi et heli on hea ja ma usun et sellist systeemi sul ka vaja ei ole mis enne sinu koju jõudmist uba mängib..aga jah..kõigepealt tulex mõelda palju raha kulutada on ja siis mis systeemi looma hakata..kodukino? või lihtsalt muusika kuulamisex?...
        F&F
          ise olen ka mõelnud s90'te ja estonia võimu peale. siis aga hakkasin mõtlema, et mis võimalused oleks kõlarid ise teha, ei tahaks nii suuri (mõõtmetelt) nagu s90'ned on. olen vaadanud poes, et pakutakse ka 4x väiksemaid. kuna heli tugevus pole prioriteet vaid pigem kvaliteet, siis kas on mõistlik midagi ise hakata kokku ehitama. (ostmise ja ehitamise vahe vist pole vaja selgitada - enda loodud on ikka südamelähedasem, kui ka peaks kehvem olema.)
          Ühesõnaga, mõtekam on alustada kõlaritest ja siis valida vastav võim.
          altz: hmm kodukino, ausalt ei tea, kas selleks peab juba mängija selle variandi välja andma (nt telekas?) ok arvutist saan nt 5.1 kaardiga kätte.
          raha - jaa suhteline mõiste, tahaks kindlasti odavalt, aga samas head. ütleme, et leida mingi kompromiss. kas 3-4000 kokku oleks mõeldav ?
            Selle eest saab suht kesise UUE süsteemi...VÕI...suht. kuulatava kasutatud süsteemi(kui kõik korras)
            TFK Audio
            #tfkaudio
            http://tfkaudio.blogspot.com/
            - Audioblogi, projektid jms.
              eks pigem pool sellest süsteemi soovist ongi kinni just ise tegemises. jah kasutatud suht noh asja saaks kindlasti, ja uue mingi mis häält teeb saaks ka. aga ISE - see on nagu peamine pigem.
                Alustada võiks sellest mida sa saavutada tahad - mis muusikat meeldib kuulata. Kui tähtis on ntx kõlarite väliskuju, kas võimendi puhul on tähtis et oleks uus ja pult ntx, või sobi ka mõni Vene imedest - Brig ntx.
                Kui kõlaritest edasi rääkida, siis kuna ilmselt rahaga priisata pole(kellel meil üldse oleks?), siis mine pigem väiksema ja lihtsama kõlair peale kui suur ja keeruline. Kehtib reegel - mida lihtsam, seda vähem saab metsa minna. Ehkki metsa saab alati minna ja see oht paraku jääb suureml või vähemalt määral alati eksisteerima. Minu vaimusilmas näen ma praegu kaheribalist riiulikõlarit, ideega hiljem neile jalad juurde teha/osta. Midwoofer 130/160 mm, ilmselt mingi soft-dome kõrge. Ultra madalat tümakat sa riiulikastidest kätte ei saa, kui aga kesksagedus ja selle üleminek kõrgele õnnestub, ei tunne sa enam mingit vajadust väga madala bassi järele(samas, sõltub kuulatavast muusikaeelistusest).
                indrek@sac.ee, +3725174765
                  tänud intz,
                  kusjuures jah, muusika poolest just bassi tegelt vaja olekski, nimelt enamus plaatidest ja mp3 on drum'n'bass. seega hea müdin ei teeks paha.
                  tuba: ~35m2 kuna aga põrandad kostavad suht hästi läbi, oleks vaja/hea kui vibrat ja müdinat jällegi põrandasse võimalikult vähe satuks. woofri puhul suht võimatu vist, aga teised kõllid olesk jah plaanis/vaimusilmas sellised pikad , ütleme, et kõlar ise oleks vast nii 60-70 cm põrandast. kas annab kuidagi ka vähendada heli kostumist alla poole. praegu s30 põrandal ja need kolistavad alla päris hästi, kõvema kuulamise puhul olen pannud kõllid padja peale, vahe on tuntav.
                    tänud intz,
                    Dipool bass ei kosta nii palju läbi
                    http://www.linkwitzlab.com/woofer.htm
                      jaa, sellega on tööd palju, palju ta tavalise woofriga vähem väristab, seda välja ei lugenud, või õigemini palju tavaline(kinnine/avatud kast).
                      kuidas on mõistlik kas 2 tavalist+ woofer või 4 tavalist + woofer. mida see võimu kohapealt muudab? kas 2 asemel 4 kasutades peaks summaarne võimsus ikka samaks jääma ?
                      kas reaalselt on sellel mõtet ?
                        Uuri ise netist, just paigutamise ja suunatud kiirgamise kohta ja muude võlude kohta.
                          Ütleme nii et kui stereo variandi peale lähed, siis kõige parem on 2 kõlarit või siis 3st kõlarist(2 peakõlarit + subbakas, vahel on subbakaid kaval ka kaks panna) koosnev komplekt kärab küll. 2+1(2+2) süsteemi võlu seisneb ruumiresonantside suhtes paremini paigutamises, paraku on ta aga kallim kui teha lihtsalt kaks kõlarit. Tibake keerukam kah.
                          Kui lähed põrandakõlarite peale, siis ikka vana hea 2ribaline variant; võid mõelda ka MTM või MMT variandi peale(tibake kallim kui lihtne MT variant).
                            viitsid palun seletada erinevust MTM ja MMT vahel.
                            mis on see teine variant, nn.mitte põrandakõlarid ?
                              ja võimendite poole pealt olen valmis teid vapralt aitama-100w-ne võim 8 oomistele kõlaritele vaid 600.- (mida rohkem kanaleid ssoovid, seda soodsamax läheb!!!)
