Non Oversampling
    Vs: Non Oversampling
    Eks kõik need arusaamatused, ja mitte mõistmised analoogi ja digitaali vahel võib kooku võtta sellise wiki laiusega:
    dBFS is not defined for analog levels, according to standard AES-6id-2006.
    No single standard converts between digital and analog levels, mostly due to the differing capabilities of different equipment. The amount of oversampling also affects the conversion with values that are too low having significant error.
    The conversion level is chosen as the best compromise for the typical headroom and signal-to-noise levels of the equipment in question.
