Väikefirma Inspire Hi-Fi teeb Technics sl-12xx mootori baasil vinüülimängijaid Monarch. See otseveo mootor on väljatöötatud üle 40ne aasta tagasi.
Sissejuhatus vägagi intrigeeriv
What do you consider to be the main advantages of direct drive?
___Due to the politics within the British audio business in the nineteen seventies and early eighties, and some vigorous marketing by some belt drive manufacturers, direct drive was never in with a chance here, which was a serious mistake in terms of the customer getting a fair choice without being brainwashed by adverts! The truth is now out though, and most people are prepared to see through what happened and are able to make a more informed decision.
A direct drive turntable is defiantly different to a belt driven turntable – it is more stable and rarely, if ever, goes out in terms of timing. Listen to a violin, piano or female vocal on even the best belt drive, and then listen to the same with a good direct drive and you can hear the notes and voice with true timing – belt drive will never be able to give absolute pitch and timing.
Why was the Technics SL1210 motor chosen as the basis for the Monarch range?
___It is well documented that the 1210 series of direct drive motors has been well ahead of the direct drive competition for many years. We knew that to manufacture the parts similar to what was in a 1210 would cost many thousands of pounds, which would in turn make the cost of a full Monarch turntable nearer to £6-7,000.
Ingliskeelselt:
Venekeelselt:
http://forum.onliner.by/viewtopic.php?t=7412253&start=20#p55999282
Tänapäevaseid otseveo mootoreid teevad Taivani tehased:
Ingliskeelselt:
Venekeelselt:
