Kas selline komplekt oleks normaalne ?
Või tasuks vaadata mingisuguseid muid elemente/võimendeid samas hinnaklassis?
Element:http://noortehnik.ee/?id=2&keel=ee&toode=539
Alpine SWR-1022D
Suurus: 250mm(10")
Sisendvõimsus(RMS): 500W
Takistus: 2+2 Oom
Sagedusala: 28-500 Hz
Ja võimendi :http://www.mts.ee/catalog/product_in...62&language=ee
Premier PM 1402
Output: RMS @4 ohm 0,5% THD 2 x 200 Watts or 1 x 400 Watts bridged
RMS @2 ohm, 2 x 350 Watts or 1 x 700 Watts bridged
Maximum output 1400 Watts
1- 2 channel
Frequency response: 10Hz-50KHz
Input sensitivity: 100mV - 6V, impedance 22kOhm
Signal to noise ratio >100dB
Fuse rating 2x40A
Lowpass Filter 50-250Hz
Highpass Filter 80-1,2kHz
Remote-On Power switching
Remote control
Bridgeable
Full MosFet
Overload protection: Overload, Thermal, Short Circuit
Adjustable RCA level inputs
Damping factor >120
Turn on delay
Gold plated RCA input and Terminals
Chassis mount ATC fuse protection
Dimensions 264 x 53 x 450 mm
Screw set, spare fuse
Kas võim elemendi ära toidab?
Kas kaitsmed on piisavad ?
Alpine SWR-1022D
Takistus: 2+2 Oom
Premier PM 1402
1- 2 channel
Fuse rating 2x40A
Remote control
Bridgeable
Full MosFet
Damping factor >120
Turn on delay
