macrom 44.07
    macrom 44.07
    On siis selline auto võimendi, sooviks rohkemat teada ..
    On kellelgi sellise vana kooli võimuga tegu olnud? Ja sooviks soovitusi mis supakat sinna taha panna või 2 supakat.
    Võimul on 2 supaka eraldi kanalit
    ja 4 tava kõlli kanalit
    Sry suht võhik sellel alal.
    Natuke siis lisaandmeid siia
    Macrom 44.07 Programmable Power Amplifier
    Specifekationer
    44.07 Maximum Power ........................................... 85Wx4
    Nominal RMS 4 Ohm, 20Hz to 20 kHz at 0.1% THD
    4 CH Output" mode ........................................... 60Wx4
    3 CH Output" mode ........................................... 60Wx2 150Wx1
    2 CH Output" mode ........................................... 150Wx2
    Output By-Pass (Preamplifier) ................................. 1-1
    Frequency response +0, -1dB ................................... 10-45.000 Hz
    S/N IHF-A-weighted ............................................ 105 dB
    Crossover frequencies
    LOW-PASS .................................................. .... 50-160 Hz
    HIGH-PASS .................................................. ... 50-160 Hz
    Crossover slope ............................................... 12dB/oct.
    Input sensitivity/Impedance
    (for nominal power output)
    Control in central position (click) ........................... 500mV/10 kOhm
    Variable control .............................................. 100-2,000 mV/10 kOhm
    Speaker impedance ............................................. 2CH 4 Ohm
    3CH 2 Ohm 4 Ohm (mono bridged)
    4CH 2-4 Ohm
    Power supply ( Negative ground ) .............................. 14.0V DC (11-16V permissible)
    Net Weight
    44.07 .................................................. ....... 4.5 kg
    Chassis size
    44.07 .................................................. ....... 280(W) x 55(H) x 300
    Aidake siis supakat leida. Ainult element sobib, kasti saab ise tehtud
    http://www.brugtstyling.dk/forum/viewtopic.php?t=14 rohkem pilte. Kas keegi oskab aidata sildamisel? Kuidas see käib, et saavutada see 2X150W?
    viimati muutis kasutaja Scott; 15 January 2010, 04:40.
    Vs: macrom 44.07
    Tundub tavaline 4 kanaliga autovõim olema. Et siis saab ntks panna woofri kahte sildaaetud kanalisse ja jääb veel kaks kanalit esikõlaritele. Woofrit valima hakates vaata kõigepealt palju sul ruumi on.
    Maailm oleks puhas ja süüta
    kui poleks õllejogurtit
    - Õ.Õ.
      No bmw 525 sedaan kerega.ikak ruumi külll.
      sooviksin siis kahte elementi pakkuge igast varjante ja hind võik jääda kuni 1500 -1700kr tk.
      tere tulnud kõik pakkumised.
      keegi midagi kuskil ei tia siis aidata
      viimati muutis kasutaja Scott; 19 January 2010, 05:21.
