Uurisin ühe bassivaljuka andmelehte ja lugesin sealt: Inductance of the voice coil 0,55 mH. Mille suurus see on? On see võnkepooli induktiivsus?
Mida tähendab?
submeistrix
Originally posted by submeistrix@Nov 6 2004, 08:15
see on vocecoil mahise see kradi toru labimoot
Võnkepooli induktiivsus ikka. Õige koht seal peaks vist see olema?:
Le This is the voice coil inductance measured in millihenries (mH). The industry standard is to measure inductance at 1,000 Hz. As frequencies get higher there will be a rise in impedance above Re. This is because the voice coil is acting as an inductor. Consequently, the impedance of a speaker is not a fixed resistance, but can be represented as a curve that changes as the input frequency changes. Maximum impedance (Zmax) occurs at Fs.Elektroonika töötab suitsu baasil.
