Warning: Undefined array key 4393 in phar://.../vb/vb.phar/library/content.php on line 2
Warning: Trying to access array offset on null in phar://.../vb/vb.phar/library/content.php on line 2
Warning: Trying to access array offset on null in phar://.../vb/vb.phar/user.php on line 1
Warning: Undefined array key "online" in phar://.../vb/vb.phar/library/content.php on line 2
Warning: Trying to access array offset on false in phar://.../vb/vb.phar/library/user.php on line 2
Warning: Undefined array key "reputationimg" in /data01/virt98243/domeenid/www.elfafoorum.eu/htdocs/includes/vb5/template.php(404) : eval()'d code on line 72
Warning: Trying to access array offset on null in /data01/virt98243/domeenid/www.elfafoorum.eu/htdocs/includes/vb5/template.php(404) : eval()'d code on line 72
Warning: Undefined array key "reputationimg" in /data01/virt98243/domeenid/www.elfafoorum.eu/htdocs/includes/vb5/template.php(404) : eval()'d code on line 77
Warning: Trying to access array offset on null in /data01/virt98243/domeenid/www.elfafoorum.eu/htdocs/includes/vb5/template.php(404) : eval()'d code on line 77
Warning: Undefined array key "birthday_search" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "joindate" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "privacy_options" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2
Warning: Undefined array key "lastactivity" in phar://.../vb/vb.phar/library/user.php on line 2
Millise kasti valiksite teie?graafikud olemas siin -
Elfafoorum
Nii saavad kõik kiire ülevaate ja kes teab mõni teine huvilinegi kohe sama asja oma projekti rakendada.
Tagasi küsimuse juurde! Millise kasti valiksite teie? Ise kaldun valima seda 61,2 L kasti, kuigi tootja on soovitanud ka 42L mahuga inverter kasti. 61,2 Liitsise graafik meeldib nagu rohkem, graafiku peak on ka u. 55 Hz peal.
Muusika stiilid mida kuulan on enamasti progressive house, techno, trance (vahel juhtub ka muid stiile). Tahaks et kast mängiks mõnusaid madalaid bassikäike aga et samas mütsuga muusika puhul annaks ka head matsu :P
Kast läheks mu Mazda 323F (luukpärasse) element luugi poole kisama.
Või on kellegil mõni parem soovitus mis mahuga kasti teha ja mis sagedusele inverter häälestada?
Ette tänades ja head ehitamist teistele soovides!
Too häälestus sagedus 40Hz'i peale siis tulemus hea(Y)
Kurat! peab ikka lõpuni lugema mis kirjutatakse!
Autosse võib kasti häälestus sagedus kõrgem olla,sest auto kere võimendab basse.
Mingi 45-50Hz peaks päris hea olema Aga mida madalam, seda kõvemini mängib 20Hz+ sagedusi
Tegin selle 61,2L kasti ja üllatus oli väga suur, kui ühendasin võimendi taha. Tunnistan ausalt, et ei oodanud selle raha eest midagi märkimisväärset.
Kokkuvõttes on bass väga meeldiv ja mängib piisavalt madalale. Tahaks ka helirõhu mingil heal päeval ära mõõta. Autos on võimatu olla, kui kuulata mõnd pikema bassimänguga lugu. Lihtsalt pea ei pea enam vastu.
Ainukeste miinustena toon välja selle pea valu pikemal kuulamisel ja kasti mõõtmed. Olen varem eelistanud kinniseid kaste. No kes püüdleb SQ poole, temale kindlasti see tulemus ei meeldiks, aga tema ei ostaks ka seda elementi.
Ostsin elemendi +- kauplusest 599kr eest ja selle raha eest on mürtsu kui palju.
Ma ise ostsin samuti selle +- elekt. Väga hea hind oli minu meelest ja parameetrid tundusid head.
Kasti valikul tekkiski ainult väike dilemma selles suhtes et 42 oleks parem ära mahutada, aga 61,2L oleks seal piiripeal, et kui see bassi ikka juurde annaks läheks seda teed kindlasti.
-> Raul? Kas sa tegid sellele elemendile sama kasti mida kenwood ise soovitas? Samade mõõtmetega mida nad kataloogis reklaamivad?
Mõtlesin kindluse mõttes sama teha. Natuke muuta winisd-ga ringi arvutada kast, et saaks tagaistmete vastu panna ilusti kasti. Eks selle nurga katsun kuidagi silma järgi paika panna :P
Täpselt nende mõõtmete järgi, mis www.kenwood.be soovitas. ei kruttinud midagi juurde, ega maha.
Kunagi on kindel plaan proovida see 42L kast ka ära, kuna praegune on meeletult suur ikkagi. Pagassi on ka vaja kasutada.
