Äkki mõni hea inimene aitab arvutada sellele elemendile kasti
Oleks väga tänulik
In-Car Measured SPL (peak @ 50 Hz): 1 watt: 105.1 dB; 350 watts: 127.6 dB; 1200 watts: 130.3 dB
Published Specs: XS-L121P5
Max Power (W): 1200
Max Power (RMS, W): 350
Sensitivity (dB/W/m): 89
Freq. Resp.: (Hz) 18 - 2k
Impedance (Ohms): 4
D (mm): 250
D (inch): 9.8
Rdc (Ohms): 3.2
Fs (Hz): 26.4
Qts: 0.42
Qes: 0.44
Qms: 5.86
Vas (Lit.) : 55.5
Vas (ft_): 1.96
Mms (g) : 219.0
Lvc (mH) : 1.2
Xmax (mm) : 7.5
Xmax (inch) : 0.3
BL : 16.1
Oleks väga tänulik
Max Power (W): 1200
Impedance (Ohms): 4
D (mm): 250
D (inch): 9.8
Rdc (Ohms): 3.2
Fs (Hz): 26.4
Qts: 0.42
Qes: 0.44
Qms: 5.86
Vas (Lit.) : 55.5
Vas (ft_): 1.96
Mms (g) : 219.0
Lvc (mH) : 1.2
Xmax (mm) : 7.5
Xmax (inch) : 0.3
BL : 16.1
