Teab keegi, kuidas kõiksugu parameetreid mõõta, kui on supikas, millel ühtegi parameetrit kirjas pole? Oleks vaja talle võimalikult hea kast ehitada, sõbraga väike võistlusmoment 8). Mäletan, et vaja oli multimeetrit ja takistit, ülejäänu on tume maa. Vajaduse korral on olemas võimalus ka generaatoreid-osse jm sellist kasutada.
Valjuka parameetrite mõõtmine
Bassbox pro-s selline jutt "Driver Test-is"
I N S T R U C T I O N S
(Please use the scroll bar to view all the instructions.)
The following test equipment is required:
1. Audio signal (sine wave) generator.
2. Accurate frequency counter.
3. Power amplifier (100-200 W) capable of flat power response
below 20 Hz.
4. 1000 ohm resistor (2 watt or greater).
5. Voltmeter (accurate at low voltages).
6. Accurate ohmmeter.
7. Hanging apparatus for suspending the driver in mid air
away from any surface or obstruction.
8. Test box (see information below):
Speaker Diameter Test Box Volume
130 cm 3.5 liters
200 cm 15 liters
250 cm 30 liters
300 cm 60 liters
380 cm 120 liters
460 cm 170 liters
The illustration above shows how to wire the test setup. The signal generator should be plugged into an input of the amplifier. The frequency counter should be connected across the output of the signal generator so it can measure the frequency of the signal. The output of the amplifier should be connected to the driver with the 1000 ohm resistor in series with the positive lead.
Enter the name of the driver manufacturer (40 characters or less) in the box above the Next button then press the Next button.
