Elemendiks on: Clarion SW3011
Võimendiks on: Blaupunkt GTA 2 Special
Number of channels 2/1 ch Class A/B
Max. Power@4 ohms 2x110 / 1x375 watts
Max. Power@2 ohms 2x170 watts
RMS Power@4 ohms 2x55 / 1x170 watts
RMS Power@2 ohms 2x85 watts
Frequency response 10 - 26000 Hz
Signal/noise ratio > 90 dBA
Distortion factor at nominal power < 0.05 %
Input impedance > 10 kOhms
Attenuation factor > 100
Input sensitivity 0.1 - 8 V
Stability 2 ohms (4 ohms bridged)
Low-pass filter 50 - 250 Hz (12dB/Octave)
High-pass filter 80 Hz (12dB/octave)
Bass Boost 0 - 12 dB at 45 Hz
Kasti siis vaja autosse: mida väiksem seda parem
Oleks väga tänulik, kui saaks näpunäiteid ning täpsed mõõtmed
