Äkki keegi oleks nii hea ja arvutaks välja selle kõlari jaoks bandpass ja inverter kasti mõõtmed. ... ette tänades 8)
Vdo Hps10
ei ole kedagi, kes viitsiks natuke arvutada ??? ... noppisin andmed ka välja
Model HPS10
Description Subwoofer
Specification
Max. Power Watts: 800
Nominal Power Watts: 300
Sensitivity dB/1W/m: 92
Nominal Impedance (Ohm): 4
Frequency Response: 24-400Hz
Materials
Cone: Nomex/Kevlar/Glassfibre Composite
Basket Material: Cast Aluminium
Woofer Magnet: Strontium Ferrite
Voice Coil info: Aluminium
Connectors: Gold-plated
Dimensions and Weight
Woofer Size: 250 mm
Mounting Diameter Woofer: 239 mm
Mounting Depth: 122 mm
Thiele Small Parameters HPS 10
Min. Impedance/ at Freq Zmin(Ohm/ Hz): 4.0/154
Maximum Impedance Zo Ohm: 25.7
DC Resistance Re Ohm: 3.3
Voice Coil Inductance Le (mH): 1.6
Capacitor in series with 4 Ohm Cc (µF): 80
Resonance Frequency fs (Hz): 46.0
Mechanical Q Factor Qms: 4.44
Electrical Q Factor Qes: 0.64
Total Q Factor Qts: 0.56
F (ratio fs/Qts) F (Hz): 82
Mechanical Resistance Rms (Kg/s): 7.38
Moving Mass Mms (g): 113.2
Suspension Compliance Cms (mm/N): 0.113
Effective Cone Diameter D (cm): 21.2 2
Effective Piston Area Sd (cm2): 352
Equivalent Volume Vas (ltrs): 18.1
Force Factor Bl (N/A): 12.9
Linear Xmax Peak Xmax (mm): 12.5
Max Mechanical Xmax Peak Xmax (mm): 22
Voice Coil Diameter d (mm): 51
Voice Coil Length h (mm): 33
Voice Coil Layers n: 4
Flux Density in Gap B (T): 1.04
Total Useful Flux (mWb): 2.5
Height of the Gap (mm): 8
Diameter of Magnet (mm): 147
Height of Magnet (mm): 35
Weight of Magnet (kg): 2.42
