Valjuka andmed on sellised:
Type: Standard one-way driver
Company: International Jensen Inc.
No. of Drivers = 1
Fs = 31,3 Hz
Qms = 6,739
Vas = 67,82 liters
Xmax = 5,23 mm
Sd = 318,9 sq.cm
Qes = 0,425
Re = 3,66 ohms
Le = 1,66 mH
Z = 4, ohms
Pe = 150, watts
Kui suure kasti peaks tegema ja kui pika inverteri toru?
No. of Drivers = 1
Fs = 31,3 Hz
Qms = 6,739
Vas = 67,82 liters
Xmax = 5,23 mm
Sd = 318,9 sq.cm
Qes = 0,425
Re = 3,66 ohms
Le = 1,66 mH
Z = 4, ohms
Pe = 150, watts
