SB Scoustics Gema
    SB Scoustics Gema
    Tere.
    Tahaks teha Gema kõlari joonistes muudatuse ja kasutada suuremat 6,5 tollist Satori MR16P-8 elementi mille läbimõõt on 3cm suurem. Siis peaks vist kõlari joonist muutma niipalju et kesksagedusel oleks 20 liitrit mahtu ja bassile jääks liitrid samaks. Küsimus oleks et mis poolkaared 90 kraadi märgiga sinna joonistatud on ja kas pean tsentri samaks jätma võin nihutada ülespoole koos kõrgsagedusega.
    Open Source Kit: Not available as full kit, read below for details. Gema is a large 3-way speaker paying homage to the classic speaker of the 1970's. Generous enclosure proportions fitted with large bass drivers were the bee's knees at the time. And for good reason! The Gema is our take on a retro-styled speaker, and the much loved 12″ SB34NRXL75-8 lays the foundation of a deep, well controlled and tuneful bassline. The dedicated midrange is covered from 680Hz and all the way up to 3kHz by the 4″ paper cone SB12MNRX2-25-4 which is characterized by good efficiency, low moving mass and great linearity resulting in excellent midrange clarity. To perfectly match the articulate and open midrange the top end is handed over to the 1 inch soft dome SB26STAC-c000-4 equipped with die-cast aluminium faceplate, optimised rear chamber and full copper cap. The well braced cabinet is designed with a large slot port tuned to 28 Hz opening to the front of the speaker and a generous sealed enclosure for the dedicated midrange. We highly recommend building the speakers from high quality 18mm plywood. A good starting point for the placement of the Gema would be a spacing of 2.5-3 meters between the speakers with generous clearance to any side and rear walls and ideally on a stand or plinth elevating the speaker about 25cm from the floor and tilted back at about 6 degrees and a slight toe in. The tweeter and midrange are intended to be on the outside, but this will depend on the room - as usual, we encourage you to experiment with speaker placement to suit your taste and listening space. Open Source Kit Gema is an open source kit meaning the speaker is fully developed and documented by SB Acoustics and you are free to use the plans.
    viimati muutis kasutaja audiohoolik; 04 m 2024, 16:36.
    Need 90 kraadi näitavad, et vastava ava servad on 45 kraadi faasiga.
    Kas valjuka tsentrit oleks vaja nihutada ja kuhu suunas, sellele ei saa keegi väga kindlalt vastata ilma katsetamata.
    Algsel joonisel on kõrgete ja kesksageduse keskpunktid samal vertikaalsel teljel, siis on suunakatakteristik kõrgete ja kesksageduse vahelises filtri alas kõige tõenäolisemalt vasakule ja paremale suunas sümeetriline ja nii oleks ka mõistlik teha, kui kesksagedus teise valjuka vastu vahetada.
    Vaatasin ka MR16P-8 ja SB12MNRX2-25-4 graafikuid ja tundub, et ka filtrit peab vist natuke ümber tegema. MR16P-8 ei saa SB26STAC samal sagedusel kokku liita kui SB12MNRX2-25-4-ga või vähemalt mitte sama hästi samal sagedusel. MR16P-8 on natuke väiksema tundlikusega ka.
    viimati muutis kasutaja moi; 05 m 2024, 00:00.
      Tänan vastuse eest. Ma olen sellega arvestanud et filtrit peab muutma aga praegu kasutan seda kesksagedust ja väga rahul.Mul on veel üks paar nelja oomiseid Satori MR16PNW-4 mis sobivad võib-olla paremini. Kindlasti tahan katsetada.
        Mina leian et ei pea suuremaks tegema. Praegune kamber on 12L (võib-olla mõni targem seletab mina annab nii väikese woofri nagu SB12MNRX panek 12L kasti ?). MR16P jaoks on Qt=0,7 kusagil 9-10 liitrit, niiet 12L oleks juba overdamped. Teiseks, mid to woofer lõige on 680Hz, Qt mõjud peaks eelkõige avalduma alla 300Hz juures. Lisaks pead sa ju kambri kõrgust suurendama 4-5 cm. et uus MR16P esipaneelile ära mahuks, mis annab veel paar liitrit juurde (suureneb ka bassi kamber, kuid tundub et sealt tulevad liitrid annavadki nati bassiotsa juurde). MR16P võiks jah lõigata allpool 2,5kHz tundub, tweeter elab selle üle küll.
        PS. mida mina teeks (aga see oleks juba suurem filtri ümberehitus) - viiks MR16P lõike bassiga alla 400Hz.
