PASUNAD?
    PASUNAD?
    Püüan asja lihtsaks teha. Teemas on punktid 1.0, 2.1 ja 2.2. Point on see kas punktis üks olev driver käib punktis 2.1 või 2.2 kirjeldatava horni külge ? - ühesõnaga kas saan nendest kolmest asjast kahega ühe pasuna kokku panna kui tellin ? Veel mis tähendab punktis 2.1 "Bi radial" ?
    1.0.
    EMINENCE COMPRESSION DRIVER PSD-2002-S (1" / 8 ohm / 80Wrms) WITH SCREWHEAD
    Specifications
    throat size: 1", 25.4mm
    impedance: 8 ohm
    power rating:
    1.6kHz @18dB: 80Wrms
    resonance: 550Hz
    usable frequency range: 1.5kHz to 20kHz
    sensitivity (1W @1m on axis on horn): 105dB
    magnet weight: 0.96kg, 34oz.
    voice coil diameter: 2", 51mm
    voice coil former: kapton
    diaphragm material: titanium
    mounting information:
    overall diameter: 5.25", 133mm
    depth: 2.2", 56mm
    mounting holes B.C.D.: 3 x M6 on 2.25" BHC
    mounting thread: 1 3/8" 18 NEF ext.
    PILT
    2.1.
    EMINENCE HORN FLARE H290 (1" BI-RADIAL)
    Specifications
    type: bi-radial
    throat size: 1", 25mm
    dispersion: 90° x 40°
    lowest rec. crossover: 1kHz
    WxHxD: 11.4" x 6.5" x 5.9", 290 x 165 x 150mm
    cut-out: 10.9" x 5.5", 277 x 140mm
    weight: 818g, 1.8lbs
    PILT
    2.2.
    EMINENCE HORN FLARE H295 (1" CONSTANT DIRECTIVITY)
    Specifications
    type: constant directivity
    WxHxD: 12.1" x 6" x 4", 307 x 152 x 102mm
    cut-out: 10.5" x 4.3", 267 x 109mm
    weight: 591g, 1.3lbs
    PILT
    põmst jah, paistab et esimene on siis element, ning teine ja kolmas on erineva kujuga pasunad sellele (ei ole kindel et sellele)
    EDIT: paistab et see element sobib neile mõlemale, sest kaelused klapivad (1")
