Warning: Undefined array key 4393 in phar://.../vb/vb.phar/library/content.php on line 2
Warning: Trying to access array offset on null in phar://.../vb/vb.phar/library/content.php on line 2
Warning: Trying to access array offset on null in phar://.../vb/vb.phar/user.php on line 1
Warning: Undefined array key "online" in phar://.../vb/vb.phar/library/content.php on line 2
Warning: Trying to access array offset on false in phar://.../vb/vb.phar/library/user.php on line 2
Warning: Undefined array key "reputationimg" in /data01/virt98243/domeenid/www.elfafoorum.eu/htdocs/includes/vb5/template.php(404) : eval()'d code on line 72
Warning: Trying to access array offset on null in /data01/virt98243/domeenid/www.elfafoorum.eu/htdocs/includes/vb5/template.php(404) : eval()'d code on line 72
Warning: Undefined array key "reputationimg" in /data01/virt98243/domeenid/www.elfafoorum.eu/htdocs/includes/vb5/template.php(404) : eval()'d code on line 77
Warning: Trying to access array offset on null in /data01/virt98243/domeenid/www.elfafoorum.eu/htdocs/includes/vb5/template.php(404) : eval()'d code on line 77
Warning: Undefined array key "birthday_search" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "joindate" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "privacy_options" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2
Warning: Undefined array key "lastactivity" in phar://.../vb/vb.phar/library/user.php on line 2
Kumba valida kas 4 ribaline ovaal või komponendid -
Elfafoorum
Nom. võimsus (4 Ohm) - 4 x 65/2 x 150 W
Nom. võimsus (2 Ohm) - 4 x 100 W
Low pass filter - 50Hz-250Hz (variable)
High pass filter - 80Hz-1.2kHz (variable)
Frequency response: 5Hz-50kHz +1/-1dB
Signal to noise ratio: 100 dB
Stereo separation: 90 dB
Input sensitivity: 200mV-6V
Input Impedance: 22 kOhm
Fuse Rating: 1 x 40A
Kardan et see 4x50W on max. võimsus ja ei toida mu esikõlareid ära
(ovaalid või komponendid valiksin 50-75W rms kandis, 50 piisaks mulle küll tegelikult) sellepärast valisingi selle 4 kanalise bochmanni võimu et sellega esikõlareid ka toita, muidu oleks võtnud ühe 2 kanalise ainult subw. jaoks. Mis te arvate sellest?
Aga ovaalid või komponendid paneksin juhi ustesse ja sellega oleks kogu süsteem.
Praegu olen rohkem hakanud kalduma komponentide poole, et saaks teravate kõlari armatuuri kõrgusele tõsta, muidu sealt alt ukse seest ei kostu neid teravaid vist palju enam ülesse. Samas on natuke umbusaldust nende ovaalide suhtes just see et pole mingeid filtreid :P
Süsteemilt ootaksin meeldivat heli, ei aja super kvaliteeti taga ega palju db (esialgu vähemalt :P kes teab mis plaanid edasi tulevad). Tehase ovaalid hakkavad ära tüütama. Tahtsin midagi paremat, et helipilt oleks rikkam ja autosõidud läheksid meeldivamalt.
Mis arvate teie sellisest setupist, või mida oskaksite oma kogemustest soovitada ja milliseid komponente valida?
Teretulnud on ka muude komponentide ja võimude soovitused?
Hinnaklass oleks, võim kuni 2000 eeki.
Komponendid kuni 1200
+ muud vajalikud jubinad kaablid ja asjad.
mitte orion vaid oris ja ma arvan et nendest need ka kõige mõistlikumad kuna madala jaoks sul juba subbar olemas siis muude sageduste jaoks oris. Ei pidavat kõige kehvem olema seega bochmanni võid kohe ära unustada neid ma kuulnud ja need väga jamad on. Ja ovaalid on jamad kesksageduse esitajad seega soovitan julgelt orist
Tänan vastuse eest. Oris jah just :P väike näpukas, mõtlesin üht ja kirjutasin teist.
Tundub küll et tulevad need orised. Hertzidel tundusid crossoverid kahtlaselt väiksed.
Nüüd veel mure võimuga et millist valida, hetkel 3 varianti üks on seesama bochmanni oma mis esimeses postituses.
Ei suutnud ainult selle SSS-i kohta midagi netist leida, firma lehtegi ei leidnud.
2. SSS 4000
Output: RMS 4 @ Ohms 4 x 75 Watts or 2 x 200 Watts
Maximum output 2000 Watts
2 – 3 – 4 channel
Frequency response: 5Hz-50 kHz
Signal to noise >100dB
Stereo separation >60 dB
Fuse rating 2 x 25A
Lowpass Filter 2x 40-300Hz, 12dB
Highpass Filter 2x 40-300Hz, 12dB
Bassboost 2x +6 dB +12dB @ 45Hz
Remote-On Power switching
Bridgeable
Full MosFet
3.
Jackson PA 4000
Output: RMS 4 ohms 4 x 75 Watts or 2 x 150 Watts
2 - 3 - 4 channel
Frequency response: 10Hz-40kHz
Input sensitivity: 200mV - 4V impedance 10KOhm
Signal to noise ratio <100dB
Lowpass Filter 40-250hZ 2x
Highpass Filter 80Hz-1,2KHz 2x
Bassboost +6 +12dB
Trebleboost +6 +12dB
Fuse rating 60A
Bridgeable
Full MosFet
Hind: 1810.-
Star soundilt SSA-460 - 1950.- see oleks veel taskukohane
4 kanalit, 4x 60w rms, 2x160w rms, 2x25A kaitse. HP/LP filter ka olemas.
Valik on raske :P Kas star soundi kiidetakse muidu?
Orise võimud läksid hinnaskaalast välja juba Üks toxicu võim meeldis mulle ka veel, aga selle tellimisega pidi 3 nädalat minema. Tahaks juba varem ehitama hakata
Kardan et seda orise AS-6.2 komponente ei saagi jäin hiljaks.
Veel oleks variandiks
Hertz – DSK165 Kit 2way with grille 16,5cm –----- 950 eeki on 13 cm,
Nom 80W
4 ohmi
50- 21 khz freq resp.
93 dbl sensitivity
Hind 990.-
mis sulle seal streetrace foorumis soovitatud on ???
Muidu kui oristest ilma ja ki´hk nii suur siis äkki oleks juba mõtekam võtta strasoundi kompod ja võim, need suht odavad ja selle raha eest pidavat küllalt normid asjad olema. Niipalju kui mina Bochmanniga kokku puutunud siis seda ei saavitaks mitte kellelegi.
Streetraces soovitati nendest Jacksoni võim valida või starsound (ühe nendest kahest kindlasti võtangi).
Ootan laupäevani ära, ehk veab ja saan ühed teised Orised (CL62). Kui ei saa siis on mul veel valida Starsoundi SSC 650CK või Jackson SP 165 MK2 komponendid. Jacksoni kõlarite kohta ei ole eriti kuulnud midagi, aga otsin netis ringi veel vaatan mis leida annab.
