The line length should be 1/4 wavelength tuned to the resonant frequency of the chosen speaker IN THE BOX VOLUME CREATED BY THE TOTAL T-LINE CROSS SECTIONAL AREA TIMES LENGTH, and as if the box were a closed box. This is the hard part, as the line stuffing affects both the total apparent line length AND the total apparent box volume simultaneously. I will discuss this later.
Kas ma sain nüüd õieti aru: Liini pikkus peab olema neljandik kasti resonantssageduse lainepikkusest, kui kasti ruumala on arvutatud kinnise kasti jaoks ning see võrdub liini pikkus X liini läbilõike pindala?
