Tekton Design Double Impact kõlari bassielemendid
    Given its exceptional sonic performance often rivaling speakers at significantly higher price points, the Tekton Design Double Impact stands as a disruptive force in the audio market…
    Kas keegi tunneb ära, milliste woofritega tegu? (10")
    viimati muutis kasutaja hipster; 22 April 2020, 13:20.
    Vs: Tekton Design Double Impact kõlari bassielemendid
    Siin on natuke parema resolutsiooniga pilte https://www.audiocircle.com/index.php?topic=153698.0
    või see https://www.tektondesign.com/uploads.../di11_orig.jpg
    Ehk huvitab miilise tootja liinilt need valjukaid otseselt tulevad?
    viimati muutis kasutaja moi; 22 April 2020, 13:34.
      pakun puusalt: https://www.thomann.de/intl/ee/eminence_ragin_cajun.htm
      see võib ka olla: https://www.thomann.de/intl/ee/emine...end_bp1024.htm
      viimati muutis kasutaja olavsu1; 22 April 2020, 16:25.
        Tundub, et sa oled õigel teel, tüüp võibolla on Legend BP102-4 aga tootja on kindlasti Eminence. Väga tõenäoliselt on see mingi tüüp, mida avalikult ei müüda ja tehakse ainut Tektoni jaoks.
          Nende Pendragon mudel kasutab samasuguseid bassielemente, ühest arvustusest leidsin sellise info:
          Second, there is the driver compliment. An amazing array of two 10” drivers and three 1” tweeters in at 2-way design, affirming Tektons belief in melding HIFI and pro loudspeaker design as the woofers are right from Eminence’s catalog with the tweeters from the HIFI driver company SB Acoustics. The woofers are fairly standard pro audio drivers and being such, perform well with a soft roll off at their upper pass-band which is needed to mate a 10” woofer to a 1” tweeter.
          Arvatavasti see siis:
          Speaker Impedance: 8 Ohm, Power rating: 200 W RMS, One of the most popular loudspeakers for electric bass applications, Ideal for all 3x 10", 4x 10" and 8x 10" speakers, Also suitable as a mid-range speaker in PA systems or 3-way bass speakers
          viimati muutis kasutaja hipster; 23 April 2020, 11:01.
