TT-501 USB Record player sai siis lelline asjake soetatus ,et veidi LP-si salvestada. Kõik kena aga kui üritan plaate läbi oma võimu PHONO sisendi kuulata,siis võimendab metsikult üle. Kasutades teisi sisendeid saab küll kuulata ,aga helikvaliteet meenutab pigem sääse pininat. Oli mul kunagi ka mingi analoog mida andis ümer lülitad nii ,et PHONO sisendiga kuulata sai. Selle pillil seda kahjuks pole. KES AITAKS?
Või vastasel juhul müün selle pilli maha!
The USB-record player is the ideal solution for archiving your records. Via the USB-cable the device is connected with the PC, the accompanying software is installed and you can start. Via the Line-input even the audio signals from the other analogue sources can be digitalised.
Driver can be downloaded free.
Included in the delivery:
Audacity software, USB cable, Audio cable, dust cover
Highlights:
USB connector allows you to record your vinyl collection directly onto a PC or Mac
In-built pre-amplifier
Line input
Features:
Line-level audio output (cinch) for connecting to the stereo system
In-built equaliser pre-amplifier.
Highlights:
Line input
Features:
