Kas tasub osta sellist digidüünerit 180 EEK
    Tere
    Miks mu eelmine teema ära kustutati? Mis sellele viga oli, appi hullem kui Pagari tänava keldrivennad juba?
    Loodan et ei kustutata nüüd seda teemat, (no kui foorumis küsida ka ei või siis mis foorum see üleüldse on, mingi kompleksides jootekolvidega tüüpide õllekas vai, kus asjaga mitte kursis inimene saab kohe sulatina näkku ja vana kondeka koluga otsaette?)
    Kas on mõtet osta taolist seadet? Kas tegemist on digitüüneriga? Kas Eestis asi töötaks?
    Tellides tuli hinnaks koos postikuluga 180 EEK
    Tänud vastuste eest (mitte sõimu ega tögamise eest!)
    Tehniline inff:
    Features:
    this digital errestrial receiver (DTR)will take you to the new nd exciting world of digital television.
    a world of crystal clear widescreen pictures,digital sound,more information and new services,all this and
    more on "free to Air"digital elevision
    to make full use of your new DTR please take the time to familliarize yourself with the extensivefeatures of the unit detailed in this user's guide
    MPEG-2 digital & fully DVB-T compliant
    automatic pal/ntsc conversioin
    1000 channels tv and radio programmable
    8 different favorite groups selection
    on screen display with osd multi-language
    fully support to 7 days electronic program guide(epg)
    picture in graphics(PIG)support
    256 colors on screen display
    channel search in automatic,manual and network search
    various channelediting
    function(favorite,move,lock,skip,delete,rename,fin d,sort)
    parental control forchannels
    plug and play installatin,with anease to use menu system
    software upgrades through rs232 port and recceiver to receiver
    time set by GMT off set automaticand manual,summer time support
    5 event timers,off/once/daily/weekly/monthly mode
    subtitle support dvb en300743 and EBU
    teletext support dvb ETS300743 by VBI and OSD
    automatic save for last channel
    support logic channel Number(LCN)
    active antenna power supply control
    Vs: Kas tasub osta sellist digidüünerit 180 EEK
    MPEG-2 : Soome vaatamiseks. Kaardi pesa ei ole, seega ainult vabad MPEG-2 kanalid.
      Nii ta on,et selle tüüneriga saab ainult soome digi tv-d näha,sest meie maapealne digi on mpg 4 formaadis ja seega mingit pilti ette saada pole lootust.Võib olla ,et heli isegi tuleb läbi.Aga Raplas ei saa arvatavasti ka soome levi kätte.Nii,et ei tasu tellida kui just soome elama ei lähe
        Heli tuleb ja EPG ka, aga seda on ilmselt vähe.
          Esmalt postitatud imees poolt
          Tere
          Ausalt öeldes, mina kustutaks selle siin samuti ära. Miks? Sest kui küsija ei saa arugi mis foorumiga tegu siis jah...
          Siin on spetsiaalselt sellistele küsimustele oma koht - ja see ei ole Trash vaid Hinnapäringu ja OSTUABI foorum. Selle foorumi sissejuhatus ju lausa kirjutab - "soovid nõuannet mida ja kust osta?" http://www.elfaelektroonika.ee/fooru...splay.php?f=32
          Leplik mode võiks selle siit lohistada just sinna ja kõik oleks korras, võibolla jääb küsijal mahti isegi järele mõelda kes siin kompleksides on...
