Follow me home mooduli installatsioonil abi vaja
    Hei!
    Olen juba siin pikemalt aega netis tuhlanud ning korraliku installationi manuali ei leia.
    Leidsin kuskillt välismaa foorumist vaid sellise info:
    - black wire -> ground
    - red wire -> 12V fused power
    to install the following 4 wires you will have to cut the low beam light wires that come from the fuse box to the headlight switch
    - yellow -> connects to the end that goes to the fuse left low beam light light
    - orange -> connects to the end that goes to the fuse right low beam ligt light
    - yellow/black -> connects to the end that goes to the low beam light left side
    - orange/black -> connects to the end that goes to the low beam light right side
    - 2x blue -> door trigger wire minus triggered signal
    - 2x brown -> door trigger wire plus triggered signal
    Moodul on ise selline:
    Endal karbiga kaasa ei tulnud installationi manuali.
    Aitäh!
    Vs: Follow me home mooduli installatsioonil abi vaja
    Esmalt postitatud Silver88 poolt Vaata postitust
    Siis küsi müüjalt. Skännib sisse ja saadab sulle mailiga. Kuulutuses selgelt öeldud, et Karp sisaldab valgusandurit, ühenduskaablit, kaitset ja paigaldusjuhendit.
