Lugu siis selline, et otsustasin panna xenonid. Nüüd kahjuks veateade ees.
Ideid? Minu multimeetriga sellist takistust ilmselt mõõta ei saa, seda ei tea ka mis läks valesti. Uurisin oomipoest, neil sellised 13mohm takisteid ei ole.
The sensor for the current is a 5 pin plug-in shuntresistor module located on the lower left side of the CEM. It's a 1 x 2 inch black thin module. On most markets, the shunts alongside the low beam shunt are not mounted. The shunt contains two resistors; 10 mohm between pins 3 & 2, and 28,5 mohm between pins 1 & 2. The current to the headlamps runs from pin 3 to pin 2. Remove the shuntBy drilling a 2mm hole in the shunt, in the second groove above pin 3, the resistance will increase to 13 mohm and the CEM will see a 30% times higher value for a given current. .
