Ülikõrgsageduslik (gigahertsid ! lainejuhitehnika. Nii kõrgetel sagedustel kasutatakse koaksiaalkaabli asemel lainejuhte, põhimõtteliselt on need kandilised või ümarad torud ja laine levib sellise toru sees. Tegu vist mingi lahendiga, täpsemalt ei oska arvata.
Their purpose was to disconnect the receiver from the antenna during transmission. In other words, they acted as a switch. Anti transmit-receive disconnect the transmitter from the antenna during reception. The TR tube is the most common receiver protector technology in use today.The presence of a high power signal will cause an arc between the cone gaps. This will ionize the gas in the region of the cones, thus causing most of the power to be reflected from the device. If the power is high enough, the input window will fire as well, providing additional protection.
"Directly or indirectly, all issues related to sound should be decided by the ear as an organ of hearing: conclusions that are given by the ear is no longer necessary to challenge.Lord Rayleigh (John William Strutt)
Kui mälu mind ei peta siis kasutati seda detaili laevanduses ja sellises seadmes
nagu lokaator.
See on see seade, mille antenn ülemisel laeva dekil või siis isegi masti peal ringi käib
ja kaptenisillal siis on seline ekraan kus roheline kiir ringiratast käib ja näitab lähedalasuvaid laevu ja muid objekte
