Arvuti kaugjuhtimine IR-kaugjuhtimispuldiga
    Keerasin vastuvõtja teist pidi ning töötab !!! Kõik on nüüd korras, ainult on jäänud see tarkvaraline külg. Kuidas winampis play, stop, pausi ja kerimist panna ?
    Kui midagi ei saa untsu minna, siis midagi ikkagi läheb...
      vaata winampi shortcut'e
      umbes midagi sellist on nad
      Key Action
      F1 About Box
      Ctrl+A Toggle Always-On-Top (all but playlist editor)
      Ctrl+Alt+A Toggle Always-On-Top (playlist editor)
      Ctrl+W Toggle Windowshade mode
      Ctrl+D Toggle Doublesize Mode
      Ctrl+E Toggle Easymove
      Ctrl+T Toggle Time Display Mode
      Alt+W Toggle Main Window
      Alt+E Toggle Playlist Editor
      Alt+G Toggle Graphical Equalizer
      Alt+T Toggle Minibrowser
      Ctrl+Tab Cycle through different Winamp windows
      Alt+S Go to Skin selection
      Ctrl+P Go to Preferences
      Alt+O Go to Built-in Visualization options
      Alt+F Jump to Main Menu
      Alt+K Configure current Visualization Plug-In
      Ctrl+Shift+K Start/Stop current Visualization Plug-In
      Ctrl+K Open Visualization Tab of Preferences
      Ctrl+J Jump to time in current track
      J or Keypad . Open Jump-to-file Box
      Ctrl+Alt+N Spawn new Winamp instance
      *** Main Window Keyboard Shortcuts ***
      Key Action
      (options/toggles)
      R Toggle Repeat
      S Toggle Shuffle
      Alt+3 Current file info box/ID3 editor
      (playback controls)
      X or Keypad 5 Play/Restart/Unpause
      V Stop
      Shift+V Stop with Fadeout
      Ctrl+V Stop after current track
      C Pause/Unpause
      B or Keypad 6 Next Track
      Z or Keypad 4 Previous Track
      Keypad 1 Jump Ten Songs Back
      Keypad 3 Jump Ten Songs Forward
      Left Arrow or Keypad 7 Rewind 5 seconds
      Keypad 9 or Right Arrow Fast-forward 5 seconds
      L or Keypad 0 Open/Play File
      Ctrl+L or Ctrl+Keypad 0 Open/Play location
      Shift+L or Insert Open/Play Directory
      Keypad 8 or Up Arrow Turn Volume Up
      Down Arrow or Keypad 2 Turn Volume Down
      *** Playlist Editor Keyboard Shortcuts ***
      Key Action
      R Toggle Repeat
      S Toggle Shuffle
      (file io)
      L or Keypad 0 Add File
      Ctrl+L or Ctrl+Keypad 0 Add Location
      Shift+L or Insert Add Directory
      Ctrl+N New (Clear) Playlist
      Ctrl+O Open (Load) Playlist
      Ctrl+S Save Playlist
      Alt+3 View/Edit Track Info for selected track(s)
      Ctrl+E Edit Selected Track Filename(s)
      (playlist manipulation)
      Ctrl+A Select All
      Ctrl+I Invert Selection
      Delete Remove Selected Files from Playlist
      Ctrl+Delete Crop Playlist
      Ctrl+Shift+Delete Clear Playlist (same as Ctrl+O)
      Alt+Down Arrow Move Selected Files Down
      Alt+Up Arrow Move Selected Files Up
      Down Arrow Move Cursor Down
      Up Arrow Move Cursor Up
      Enter Play Selected File
      End Jump to End of List
      Home Jump to Start of List
      Page Up Move up by a fifth of a page
      Page Down Move down by a fifth of a page
      Alt+Delete Remove dead (non-existent) files
      (playlist sorting)
      Ctrl+Shift+1 Sort Playlist by Title
      Ctrl+Shift+2 Sort Playlist by File Name
      Ctrl+Shift+3 Sort Playlist by File Path and Name
      Ctrl+R Reverse Playlist
      Ctrl+Shift+R Randomize Playlist
      (playback controls (ala main window))
      V Stop
      C Pause/Unpause
      Ctrl+F4 Close (hide) Playlist Editor
      *** Graphical Equalizer Keyboard Shortcuts ***
      Key Action
      1 - 0 Increase EQ bands
      Q - P Decrease EQ bands
      ` Increase EQ Preamp
      TAB Decrease EQ Preamp
      N Toggle EQ
      S Open Presets Menu
      Ctrl+S Load Preset
      A Toggle EQ Auto-Loading
      Ctrl+F4 Close (hide) Graphical Equalizer
      *** Minibrowser Keyboard Shortcuts ***
      Key Action
      Alt+Left Go Back
      Alt+Right Go Forward
      Ctrl+L Open 'Go' Menu
      Ctrl+O Open Internet Location Box
      Ctrl+R Reload page
      Ctrl+Alt+R Update Link List
      Ctrl+F4 Close (hide) Minibrowser
        1. Kas dll ide kustutamine või ignoreerimine ei peaks halvama Girderi tööd?
        2. Nyyd sain tööle nii, et hardware on valmis(va.fotoelement) AGA grider laseb enableda selle ikkagi e. tunneb ära et hard on korras. Sellest siis kysimus: Mille järi ta aru saab et hardware on taga?
        3. Ma rääkisin yhe käbaga ja ta arvas et äkki onvõimalik fotodioodi kasutada kui teha vahele mingi transistor võimendi. On see ikka nii vä?
          Ilmselt ta tunneb ära, et pinge pordis on teist pidi, kui ilma Girderita.
          Ainult fotodioodi ei saa kasutada, ka koos võimendiga. Vastuvõtjas on 38 kHz demodulaator ja filtrid ka.
            Keegi võix mu juttu ka vahel lugeda :'( . Niih ... elu jälle selle foorumi teema all liikuma hakanud ... Oleks paar küsimust selle ir asjanduse kohta. Esitex tahax teada ,et see komplekt mida müüakse tevalos,kas seal on kõik jubinad sees,mida vaja välja arvatud pult siis ? Ainult kokku tinutada ? Ja veel tahax teada ,et kui pika juhtme võib selle com otsa ja ir vahele panna? Lugesin ,et yx pani 10 meetrit.Äkki võib veel rohkem ? Kardan ,et signaal võib ära hajuda nii pika juhtmega.
            Ahjaa...mida sellega üldse juhtida saab ??
            Ja üldse kas keegi seda asja praktiliselt kah kasutab ?
            Sai ka sõna sekka öeldud.
              Küsiks sellise küsimuse et kas seda ir andurit on võimalik jootes ka peese keerata?Käitub küll natuke imelikult...
                Saad küll tuxi keerata kuid selleks peab kivi ikka lausa sulama hakkama...
                Tevalost ostsin kunagi vaid IR-vastuvõtja, komplekti kohta ei tea midagi arvata. HElista ja küsi järgi!
                Kaabelist. Ma arvan, et asi töötab ka pikema kaabliga kui 10m aga siis peaks juhe ikka parem olema kui roti sabast lõigatav "pesunöör". Põhiprobleem on mahtuvus - see sundib impulsid ära. Seega proovi leida võimalikult väikese mahtuvusega kaabel või pane lihtsalt 3 juhet paralleelselt. Ma oletan, et peenike valvekaabel ei ole ka hea siinkohas.
                  Veel 1 probla. Kuidas saada winamp 3 käsud tööle ??? Plugina tõmbasin ära, aga kui panen pluginast näitex play, ei tööta see värk kahjux :'(
                    Paar küsimust veel ;D
                    Kuidas saab media playeril play, stop ja pausi nuppe panna?
                    Ning sama küsimus winDVD kohta
                      Tegin eile õhtul endale kah selle tilulilu valmis. Tulemust on näha allpool. Kuna ma tegin tavapärasest natuke teise skeemiga (lüüt ning takk lisaks toitesüsteemis) siis otsustasin asja plaadi peale monteerida. TSOP on füüsilise stabiilsuse huvides veel peadpidi kuuma liimiga plaadi küljes kinni. Lühiühenduste ning oksüdeerumise kaitseks on plaat ja komponendid (v.a. TSOPi korpus) lakiga üle lastud. Arvuti asub seina ääres laua all täpselt nii et TSOP jääb silmaga toa poole. Probleemid tekkisid ainult siis kui puldiga aknast välja või monitori pihta suunata. Muidu võttis ilusti igast nurgast (tuba 3x4 meetrit ning takistusi mööbli näol küllaga). Tarkvaraga on natuke problemaatiline sest 7'se prioriteediga tõmbab masina pisut umbe (os XP, prose Duron 850@935). Langetasin prioriteedi 4 peale ning tiksub kenasti. Arvatavasti hoian Griderit sees nagunii ainult siis kui filmivaatamiseks läheb vms.
                        Niih ... mingises eelmises postituses oli see kyssa juba sees,kuid kordan seda! Mis programme saab selle puldiga juhtida ? :
                          Yx kysimus siin targematele kah.Kas seda IR pead saab kah kuskil mujal kasutada N: ilmja juhtmeta hiire puhul. Hiir nagu olemas ja vastuvõtja ka. Mõtlesin seda ,et kas vastuvõtjale saab panne veel yhte ir kylge ja näitex teise tuppa panna ,et siis saax teises toas ka hiirega mässtata??? Mis arvata ? ??? ???
                            Läbi Girderi peaks saama kõiki programme juhtida...
                              Mis oleks selle mõte? Raha kokkuhoid? Pigem läheb asi kallimaks. Kõige odavam valmislahendus (st. filter, detektor, võimendi, demodulaator) maksab 20 EEK (TSOP1738). Kui oma aega aga ei hinda siis saad ehk paar krooni odavamalt.
                                Kuidas siis ikkagi saab media playerit ja winDVD-d juhtida ???
