Kas ATtiny2313 programmi on võimalik ATmega8-le kirjutada.
Kood:
$regfile = "2313def.dat"
$crystal = 4000000
'$noramclear
Config Portb = Output
Config Portd = Input
Portb = &B00000000
Portd = &B00000000
Motor_lp Alias Portb.0
Motor_lt Alias Portb.1
Motor_pp Alias Portb.3
Motor_pt Alias Portb.2
Sensor_p Alias Pind.2
Sensor_s Alias Pind.5
Sensor_l Alias Pind.4
Do
If Sensor_l = 1 And Sensor_s = 0 And Sensor_p = 1 Then 'go along
Gosub Go
Elseif Sensor_l = 0 And Sensor_s = 1 And Sensor_p = 1 Then 'turn left
Gosub Lewt
Elseif Sensor_l = 0 And Sensor_s = 0 And Sensor_p = 1 Then 'turn left
Gosub Lewt
Elseif Sensor_l = 1 And Sensor_s = 1 And Sensor_p = 0 Then 'turn right
Gosub Righ
Elseif Sensor_l = 1 And Sensor_s = 0 And Sensor_p = 0 Then 'turn right
Gosub Righ
End If
Loop
Go:
Motor_lt = 1
Motor_pt = 1
Return
Lewt:
Motor_lt = 0
Motor_pt = 1
Return
Righ:
Motor_lt = 1
Motor_pt = 0
Return
Kood:
$crystal = 4000000
'$noramclear
Portb = &B00000000
Portd = &B00000000
Do
Gosub Go
Gosub Lewt
Gosub Lewt
Gosub Righ
Gosub Righ
End If
Loop
Go:
Motor_lt = 1
Motor_pt = 1
Return
Lewt:
Motor_lt = 0
Motor_pt = 1
Return
Righ:
Motor_lt = 1
Motor_pt = 0
Return
