Originally posted by @ndres+Jan 23 2005, 17:08--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (@ndres @ Jan 23 2005, 17:08)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Elektrik@Jan 23 2005, 16:32 Google r22gib et ongi Intel SL37LM "emme" aga kuidagi segane info selle kohta seal.
Jutt käib Inteli lõunasilla kiibist, mida võidakse kasutada erinevate tootjate erinevatel emmedel.
Mis firma arvutiga muidu tegemist on? [/b][/quote]
Intel ikka
Mu korpuse esipaneelile on kirjutatud "kernel" ja logo on selline: k ja ring ymber. Mu arvuti on sugulasel kokku pandud. sellep2rast ma ei teagi tast midagi. Kyll ega sa ei tea yhtegi programmi mille paned t66le ja ta kirjutab kogu info arvutist. oleks vaja sest see nii imelik arvuti.
Version EVEREST v1.51.195
Homepage http://www.lavalys.com/
Report Type Report Wizard
Computer *****
Generator ***-**** ****
Operating System Microsoft Windows 2000 Professional 5.0.2195 (Win2000 Retail)
Date 2005-01-23
Time 19:05
Computer:
OS Service Pack Service Pack 4
Internet Explorer 6.0.2800.1106 (IE 6.0 SP1)
DirectX 4.09.00.0904 (DirectX 9.0c)
Computer Name *****
User Name ***-**** ****
Motherboard:
CPU Type Intel Pentium III, 450 MHz (4.5 x 100)
Motherboard Name Chaintech 6BDA/6BDU/6BPV/6BSA/6BSV/6BTA/6BTA2/6BTA3/6BTM(L)/6BTS/6ZIA / Matsonic MS7070S(D)
Motherboard Chipset Intel 82440BX/ZX
System Memory 64 MB (PC100 SDRAM)
BIOS Type Award Modular (12/17/99)
Communication Port Communications Port (COM1)
Communication Port Communications Port (COM2)
Communication Port Printer Port (LPT1)
Display:
Video Adapter ATI Technologies Inc. 3D RAGE II+ PCI (2 MB)
3D Accelerator ATI 3D-Rage II+
Monitor LG 566LM [15" LCD] (205JE05704)
Storage:
IDE Controller Intel® 82371AB/EB PCI Bus Master IDE Controller
Floppy Drive Floppy disk drive
Disk Drive QUANTUM FIREBALL ST2.1A (2 GB, 5400 RPM, Ultra-ATA/33)
Disk Drive HDS722580VLAT20 (80 GB, 7200 RPM, Ultra-ATA/100)
Optical Drive SAMSUNG CD-R/RW SW-252S (52x/32x/52x CD-RW)
SMART Hard Disks Status OK
Peripherals:
Printer EPSON Stylus COLOR 580 (Copy 2)
Printer Fax
USB1 Controller Intel 82371AB/EB PIIX4 - USB Host Controller
USB1 Controller ULi/ALi M5237 USB Open Host Controller
USB2 Controller ULi/ALi M5273 USB 2.0 Host Controller
USB Device Philips ToUcam XS
USB Device USB Human Interface Device
USB Device USB Printing Support
No peaaegu ju tundis. Neid lühendeid hakka nüüd plaadilt otsima.
Muuseas, kunagi vaevlesin sama probleemiga ühe Chaintech´ga - mark oli kleepsul, mis asus ühe PCI pesa alumisel küljel
Originally posted by Enryco@Jan 23 2005, 19:38 mida ma teen kui ma m6ne numbri leian ???
:huh:
Võimalike variantide arv on 12.
Toksi Googlisse ja uuri milline Sinu omale sarnaneb.
Chaintech´i kohta näiteks siit vaadates (Intel 440BX) võib arvata, et üle 600MHz P3 ei tunnista
Võib-olla on BIOS´i parandus, mis latti natuke kergitab?
:huh: ok seda ma arvasingi et mingi p**k on aga kuidas ma panen selle arvuti 80Gb k6vaketast tunnistama??
Asi on niimodii et kui win 2000 peal siis tunnistab seda k6vaketast aga kui 98se siise ei tunnista ning ka siis kui k6vaketas on t2itsa tyhjaks tehtud. Tahaksin tollele hoopis win 2000 peale lasta !! Kas asi v6ib olla selles et kui hakkan windowsi installeerima peaksin kasutama win 2000 bootdisck-i . praegu olen kasutanud 98se oma.
Aga kuidas muidu biose uuendust tehakse. see everest kirjutas et peaksin toda uuendama kuna to olevat juba 2 aastat vana.
BIOS-i uuendamise soovitan asjatundijale j2tta, s6bra "emme" BIOS-iga sai "nalja tehtud" ja tagajärjeks oli uue "emme" ost, Sinu jama puhul kahtlustax kas W98SE yldse tunneb neid suuri k6vakettaid, ple ise kahjuks kunagi proovind, ja asi v6ib tõesti olla ka BIOS-is, kui rohkemat ei tunne ära, aga tekib kohe küsimus: miks w2k tunneb vana BIOS-iga ja W98SE mitte. Bootdiski vahet pmst ple, kui Sa seal DOS-is aint mingit formatit teed v6i FDISK-iga möllad.
aga kui w2k peale tahad ajada siis vahet pmst ple, uuendad BIOS-i või mitte ,HDD tunneb kogusuuruses ära ja saad asja korda
kui suuremate ketaste toetust tahta, siis on vaja ainult uuemat versiooni FDISK'st
Sellega jagad pisemateks juppideks 10/70 ntx ja lased opsüsteemi peale 10Gb sektorile. Peale uuendusi peaks asi ka seda 70Gb tunnistama.
PS! Microsoft lõpetab toe win98'le 30 juuni 2006 (+/- 1 kuu)
