Win98SE MsDos.sys fail
    Juurkaustas puudub fail MsDos.sys, mis võimaldab Win98SE üles tõmmata.
    Samanimeline fail on olemas, aga see on juurikas Dos jaoks, sisu lihtsalt erinev (lühem).
    Ei tahaks kõike uuesti installida, see fail sobib kõigile Win98/98SE olemata masinast.
    Vs: Win98SE MsDos.sys fail
    Boot floppy 98/SE omaga boodid ülses, siis käsk sys a: c:
    Windows jookseb käima.
    Pärast muudad msdos.sys faili sisu: Safe Mode's
    Sisu järgmine, kui windowsi juur c:\windows
    :::::::::::::MSDOS.SYS::::::::::::::::::::::::::::
    ;SYS
    [Paths]
    WinDir=C:\WINDOWS
    WinBootDir=C:\WINDOWS
    HostWinBootDrv=C
    [Options]
    BootGUI=1
    DoubleBuffer=0
    AutoScan=0
    ;The following lines are required for compatibility with other programs.
    ;Do not remove them (MSDOS.SYS needs to be >1024 bytes).
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxa
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxb
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxc
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxd
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxe
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxf
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxg
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxh
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxi
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxj
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxk
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxl
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxm
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxn
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxo
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxp
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxq
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxr
    ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxs
    Logo=1
    :::::::::::::::::::::::::::::::::::MSDOS:SYS:::::: :::::::::::::::::::::::::::::
    Edit:
    Vahest on aitanud: lihtsalt selle msdos.sys faili kopeerimine juurikasse eelpool kuvatud sisuga.
    viimati muutis kasutaja yllsel; 28 m 2007, 11:47.
      Sain eile faili, asi korras.
      Aga siit copy/pastega peaks samuti olema võimalik vajalik fail moodustada.
      Aitäh!
