vidoekaart
    vidoekaart
    tere! probleem selles et tahaks osta videokaarti agp pessa... emaplaat on mõeldud 32bit videokaardile aga videokaart ise on 64bit. kas seda ei ole võimalik panna ?
    emaplaat http://www.dfi.com.tw/Product/xx_product_spec_details_r_us.jsp?PRODUCT_ID=3000&C ATEGORY_TYPE=MB&SITE=US
    videokaart http://epood.atf.ee/index.php?productID=8714
    Vs: vidoekaart
    inglise keel kah kehvake mul... ei saa nagu päris hästi pihta ...
    AGP 8xA 32-bit channel operating at 66 MHz, strobing eight times per clock, delivering an effective 533 MHz resulting in a maximum data rate of 2133 MB/s (2 GB/s); 0.8 V signaling. There are various physical interfaces (i.e. shape of slots), as explained in the Compatibility section below.
    AGP version 3.5 is only publicly mentioned by Microsoft under Universal Accelerated Graphics Port (UAGP), which specifies mandatory supports of extra registers once marked optional under AGP 3.0. Upgraded registers include PCISTS, CAPPTR, NCAPID, AGPSTAT, AGPCMD, NISTAT, NICMD. New required registers include APBASELO, APBASEHI, AGPCTRL, APSIZE, NEPG, GARTLO, GARTHI.
    [edit] Variations
    A number of non-standard variations of the AGP interface have been produced by manufacturers.
    64-bit AGPA 64-bit channel. Used in high-end professional graphic cards. It was once proposed as an optional standard for AGP 3.0 in draft documents, but was dropped in the final version of the standard. Ultra-AGP, Ultra-AGPIIIt is an internal AGP interface standard used by SiS for the north bridge controllers with integrated graphics. The original version supports same bandwidth as AGP 8x, while Ultra-AGPII has maximum 3.2GB/s bandwidth.
      Vs: vidoekaart
      see kaart on tavaline juust AGP kaart. siiniga ei ole sellel 64-bit süsteemil miskit pistmist, sellest vastus, et sobib küll. teisalt, kui juba videot ostma hakkad ja selle kaardi pealt ka liikuvaid asju tahad vaadata(mängida), siis eelistada võiks 128-bit kaarte. 128MB ja 128-bit kaart võib jõudluses oluliselt parem olla, kui 256 64-bit kaart. kõik sõltub muidugi ülejäänud raua võimekusest ka.
      see 64-bit 128-bit vms näitab kaardi enda siini läbilaskevõimet ehk, siis seda, kui kiiresti saab info liikuda videomälu ja -prose vahel. mida suurem number, seda kiirem see info vahetus saab olla. 128-bit ja 64-bit kaartidel ei tohiks enam ka hinna vahe eriti suur olla
        Vs: vidoekaart
        Tänud vastuse eest
        Esmalt postitatud reuter poolt
