probleem BIOS ROM Cheksum´iga
This topic is closed.
    Vs: probleem BIOS ROM Cheksum´iga
    ikka sama teema failid 0kb, ühe sain, mis oli rari pakitud, kuid lahtipakides tuli vigane .bin fail
    kes mulle selle õige faili leiab, teen nelipaki
      Esmalt postitatud sandermat poolt
      Sul ehk RAR-ga mingid probleemid..
      siin
      (pärit sealt: http://driverscollection.com/?file_id=31064 )
        pakin rari lahti ilusti ja siis tuleb sealt välja 8rd34729.bin fail. floppy aga tahab sinna awdflash.exe kõrvale samamoodi exe faili, mitte seda .bin-i
          Ei saa aru, kuidas floppy "tahab"
          Biosi fail on ju .bin ise. Awdflash.exe aga utiliit, mis selle .bin-i EEPROM mälusse kirjutab. Kui awdflash.exe käivitad, küsib ta "File Name to Program ". Oma BIN-i nime sinna panedki.
          edit: mis marki bios-i kivi on?
          Sinul siis niimoodi:
          The Boot Disk Method
          1. Create a bootable floppy disk in accordance with the instructions laid out in the manual of your particular operating system. This bootable floppy needs to be able to boot to a DOS console capable of executing normal MS-DOS batch and executable files.
          2. Download the required BIOS image file from the EPoX website.
          3. Ensure the mainboard is set at LOAD OPTIMIZED DEFAULTS and is not overclocked in any way.
          4. Copy to this floppy disk this latest copy of AWDFLASH version 8.54 and also a copy of the BIOS binary image file called 8rd34729.bin
          5. Insert the diskette into drive A, reboot your system and boot from the diskette.
          6. When booting is finished, type awdflash 8rd34729.bin /sn/py/cc
          7. then press enter to run BIOS upgrade program.
          The BIOS will automatically flash and reboot the machine.
          8. After this, press DEL to enter the BIOS setup and select to "LOAD OPTIMIZED DEFAULTS". After doing this select to "SAVE & EXIT"
          9. Please note that this does not create a backup of the BIOS binary file.
          10. For Command line help on Award Flash utility, type AWDFLASH /? at the command prompt and press enter
          viimati muutis kasutaja sebastian; 15 April 2009, 19:38.
            et õpetus on väga täpne jah, ja ma olen selle ise ka ülesse leidnud juba, aga mul ikkagi selline probleem, et see AwardBIOS Flash Utility V8.54 läheb ilusti käima, siis ilmub sinna FLASH type, kus ei näita minu biose kohta ,mitte kui midagi, teine rida on File nime to program, kuhu ma kirjutangi selle 8rd34729.bin, siis ei juhtu midagi, korraks teeb floppy häält ja siis arvuti nagu kiilub kinni ja ei toimu midagi :S
            http://web.zone.ee/sandermat/bios/
            viimati muutis kasutaja sandermat; 16 April 2009, 16:55.
              Kui su bios juba ise küsib bin faili, siis pole mingit utiliiti vaja (käivitada). Lased lihtsalt bin-i flopile ja bios ise loeb selle sisse ja salvestab ära.
                seda vaatasid sa pildilt, see pilt on tehtud siis, kui floppy on sees, awdflashi ja bin failiga, kirjutan sinna sisse selle biose update ja siis arvuti kiilub..
                  Mõnd teist flopit proovisid? Äkki on lugeja vilets või tolmune, seda kasutatakse niikuinii väga harva.
                  Mul näiteks on ta alati paksu tolmu täis, kui mingil ajal (ehk kord aastas) märkan tolmuimejaga ka A: pesasse piiluda
                    Kas see ei tähenda mitte, et tuleb kirjutada failinimi JA käsud "/sn/py/cc "?
                      Esmalt postitatud Eggy poolt
                      See just seda tähendabki
                      edit: muidugi ühele reale kogu 8rd34729.bin /sn/py/cc
                      Pärast *.bin kindlasti vahekoht ehk space ja siis käsud.
                        sinna flashi ei mahu nii palju kirjutada, sinna mahub: 8rd4729.bin /sn/py <- ja rohkem ei mahugi midagi, arvuti sellepeale ei tee ikka midagi :S proovisin ilma .bin ja kirjutasin sinna selle /sn/py/cc vahele ikka ei midagi
                        viimati muutis kasutaja sandermat; 22 April 2009, 14:02.
                          Proovi nii, et nimeta see .bin lühemaks näiteks 729.bin ja siis otsa need käsud.
                            proovisin nime lühemaks ka, ei midagi, aga siis sain siit foorumiset ühe kasutaja käest sama emaplaadi, mis oli ka rikkis, kuid biose kivi töötas seal, viskasin selle ringi ja nüüd töötab, tänud kõikidele aitajatele
