Kas Club 3D ATI Radeon HD 350 AGP Hakkaks tööle MS-6788 (FC-478) emaplaadil?
    Manufacturer:ATi Max Power Draw:95 W
    Series:Radeon HD 3k Noise Level: Moderate
    GPU:RV670 Framebuffer: 256,512 MB
    Release Date:2007-11-15 Memory Type:GDDR3
    Interface:AGP 8X Memory Bus Type:64x4 (256 bit)
    Core Clock:668 MHz DirectX Compliance:10.1
    Shader Clock:668 MHz OpenGL Compliance:2.0
    Memory Clock:828 MHz(1656 DDR) PS/VS Version:4.1/4.1
    Memory Bandwidth:52.992 GB/sec Process:55 nm
    FLOPS:427.52 GFLOPS Shader Processors:320
    Pixel Fill Rate:10688 MPixels/sec Pipeline Layout:Super-scalar MADDx5
    Texture Fill Rate:10688 MTexels/sec Texture Units:16
    emaplaat:
    • MSI MS-6788 Socket 478 ATX Motherboard
    • General Features:
    • ATX form factor
    • Intel 865PE/848P chipset
    • 400/533/800 MHz Front Side Bus (FSB)
    • Supports up to 3GB RAM (DDR266/333/400)
    • UDMA/133
    • Two (2) dual-channel IDE controllers supporting four (4) devices total
    • Two (2) built-in SATA connectors
    • One (1) dual-channel floppy disk controllers supporting two (2) devices total
    • AC'97 audio
    • Integrated 10/100 Ethernet controller
    • Expansion Slots:
    • One (1) 4 x/8 x AGP slot
    • Four (4) 32-bit PCI slots
    • Three (3) 184-pin DDR DIMM slots
    • I/O Ports:
    • Two (2) PS/2 ports
    • Two (2) 9-pin standard serial ports
    • One (1) 25-pin standard parallel port
    • Four (4) USB ports
    • One (1) RJ-45 standard Ethernet jack
    • Line-in, microphone and line-out jacks
    • Supported CPUs:
    • Pentium 4 Extreme Edition (Northwood, FSB800, L3 Cache 2MB)
    • Pentium 4 Extreme Edition 3.2 GHz - 3.4 GHz
    • Pentium 4 (Prescott, FSB800, L2 Cache 1MB)
    • Pentium 4 2.8 GHz - 3.4 GHz
    • Pentium 4 (Prescott, FSB533, L2 Cache 1MB)
    • Pentium 4 2.4GHz
    • Pentium 4 2.8GHz
    • Pentium 4 (Northwood, FSB800, L2 Cache 1MB)
    • Pentium 4 (Northwood, FSB800, L2 Cache 512KB)
    • Pentium 4 2.4 GHz - 3.4 GHz
    • Pentium 4 (Northwood, FSB533, L2 Cache 512KB)
    • Pentium 4 2.26 GHz - 3.06 GHz
    • Pentium 4 (Northwood, FSB400, L2 Cache 512KB)
    • Pentium 4 2.0 GHz - 2.8 GHz
    • Pentium 4 (Willamette, FSB400, L2 Cache 256KB)
    • Pentium 4 1.5 GHz - 2.0 GHz
    • Celeron D (Prescott, FSB533, L2 Cache 256KB)
    • Celeron D 320 2.4 GHz - 3.06 GHz
    • Celeron (Northwood, FSB400, L2 Cache 128KB)
    • Celeron 2.0 GHz - 2.8 GHz
    • Celeron (Willamette, FSB400, L2 Cache 128KB)
    • Celeron 1.8 GHz
    • Regulatory Apporovals:
    • FCC
    • CE
    • BSMI
    • C-Tick
    Package Includes:
    • MSI MS-6788 865PE Neo2-V Motherboard
    • One (1) SATA cable
    • One (1) SATA power cable
    • One (1) IDE cable
    • One (1) Floppy cable
    • One (1) I/O shield
    • One (1) Installation CD
    • Users manual
    Additional Information:
    • Notes:
    • Model: 865PE Neo2-V
    • P/N: MS-6788
    • UPC: 8 16909 00581 3
    • EAN: 4 719072 009298
    • Product Requirements:
    • ATX case
    • ATX power supply
    • Supported processor
    • Supported RAM
    • Video cardst of system
    Vs: Kas Club 3D ATI Radeon HD 350 AGP Hakkaks tööle MS-6788 (FC-478) emaplaadil?
    Toiteploki võimsus mainimata.Selle taha võib jääda.Muidu miks ei peaks toimima?
      Kui AGP plaadil olemas, siis miks mitte? Antud kaart ei taha tõenäoliselt eriti võimsat toitekat ka. 300-350w plokk on sellele rohkem kui küll.
      Estonian SPL & Sound
      @gargru
        tõesti, ma hakkasin kahtlema arvuti video kaardi DDR rammi suhtes, et äkki ei hakka toimima. Vahepeal leitsin ka GDDR3 radeon hd kaardi AGP 8x peal töötava. Kuigi jah loodan, et see siis ka tööle hakkab.
        Häid pühi!
        Taavi
          Hei!
          Arvuti mälu ja videokaarti mälu vahel mingit seost ei ole.
          Kui emaplaadil ikka sama siin, mille jaoks videokaartki, siis töötab ju igal juhul, muu ei loe.
          Lihtsalt väikesed probleemid võivad tekkida, kui videokaart tahab lisatoidet ja toitekal sellist otsa pole. On ka üleminekud müügil muidu, aga...
          PS! Kahtlen, et mudelinimeks 350, pigem prose koodi järgi 3850/3870. 3870 on üsna rahuldav kaart, aga kui õieti mäletan, vajab lisatoidet ja korralikumat toiteplokki. Korraliku tootja 450-500w on küll. Chieftek nt. Ja korralikku toidet ON vaja, olen näinud poolikuid säästulahendusi küllalt, kus tekivad imelikud vead ja ei ole õige jõudlus, aga see on ju jama.
          Rahulikku jõuluaega
          Henry
          EDIT: Kontrolli ikka kindlasti üle kas konkreetne käesolev kaart ikka kindlalt AGP siini kaart on, palju töenäolisemalt PCIe ja siis on jama! Kui on ikka AGP kaart, siis kusjuures selle kiviaja komplektile võimsaim sobiv video ja haruldane, hoia sellest kinni. AGP korralikud kaartid on haruldased ja kallid.
          viimati muutis kasutaja Henry; 25 December 2011, 19:14. Põhjus: Lisainfo
