Gigabyte GA-8IPE1000-G
    Tere! Mureks on see, et mu RAM on DDR 400MHZ aga arvuti töötab ainult 200MHZ peal, mida peaksin tegema, et saavutada see õige kiirus?
    Windows XP Home Edition sp3 32bit
    Pentium 4 Prescott Edition 3.00 GHZ
    Club Radeon 9600 PRO 128MB
    RAM 1.2GB DDR 400MHZ
    Lasting Quality from GIGABYTE.GIGABYTE Ultra Durable™ motherboards bring together a unique blend of features and technologies that offer users the absolute ultimate platform fo...
    Vs: Gigabyte GA-8IPE1000-G
    Esmalt postitatud Elegija102 poolt Vaata postitust
    WIKI
    Standard name DDR 400
    Memory clocK 200 MHz
      mis asi see siis 400MHZ veel on? kui memory clock on ainult 200MHZ?
        loe lõpuni
        PC3200 is DDR SDRAM designed to operate at 200 MHz using DDR-400 chips with a bandwidth of 3,200 MB/s. Because PC3200 memory transfers data on both the rising and falling clock edges, its effective clock rate is 400 MHz.
