Win7 probleem
    Win7 probleem
    Protsessori vahetusega uut win`i ei installinud, vanaga töötas edasi.
    Kuid arvuti hakkas mängimise ajal kokku jooksma.
    "Event viewer" annab probleemi id`ks 1000
    "sfc /scannow" leiab, kuid ei suuda parandada.
    Logisse kirjutab järgmist:
    Repair transaction
    2012-06-02 19:22:48, Info CSI 000003ff [SR] Verify complete
    2012-06-02 19:22:48, Info CSI 00000400 [SR] Repairing 1 components
    2012-06-02 19:22:48, Info CSI 00000401 [SR] Beginning Verify and Repair transaction
    2012-06-02 19:22:48, Info CSI 00000403 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2012-06-02 19:22:48, Info CSI 00000405 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2012-06-02 19:22:48, Info CSI 00000406 [SR] This component was referenced by [l:266{133}]"Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~6.1.7600.16385.Windows Foundation Language Pack"
    2012-06-02 19:22:48, Info CSI 00000409 [SR] Could not reproject corrupted file [ml:60{30},l:58{29}]"\??\C:\Windows\SysWOW64\en-US"\[l:28{14}]"iassdo.dll.mui"; source file in store is also corrupted
    2012-06-02 19:22:48, Info CSI 0000040b [SR] Repair complete
    2012-06-02 19:22:48, Info CSI 0000040c [SR] Committing transaction
    2012-06-02 19:22:48, Info CSI 00000410 [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired
    Kui üritan "Repair`ida" olemasolevat windowsit (64bit) sama plaadiga, kust kunagi installisin siis mõlemal juhul (64 ja 32bit) väidab, et ei ole sama versioon ja edasi minna ei saa.
    Kas on veel mõni variant või aitab ainult värske install?
    Vs: win7 probleem
    1. Remove kõik SP uuendused (see on põhjuseks miks plaati valeks peab) ja proovi siis uuesti, kui ei aita tuleb uus windows.
    2. Tee Control Panel\System and Security\Backup and Restore võlurist oma kasutajast BU
    samas soovitan varundada ka FONTS (kui neid vajalikuks pead) ja mõned Programmi kaustad (üldjuhul varundan ma Program Files, Program Files (x86), Users ja asun uut windowsit peale meisterdama.
    Kui uus windows peal, hakkad vaikselt programme installima ja BU kaustast vajalikke faile üle kirjutama.
    PS! Windowsit installides ei pea sa formatit tegema, võid lihtsalt uue windowsi kõrvale installida ja aegamööda üle kolide vanast windowsist uude!
      Vs: win7 probleem
      Vaata enne igaks juhuks BIOS ka üle, mis muutusi seal on.
        Vs: win7 probleem
        Ära jandi selle parandamisega, raiskad hulga aega ja närvi, aga pärast on win-il ikka miski kiiks küljes.
        Ma teeks nii:
        Biosis valiks "optimized default" vms., et emme keeraks oma sätungid sobivaks.(Kui muidugi käsitsi häälestamise soovi pole.)
        Siis käiks ketaste, buutimise ja power managmendi üle.
        Ja siis puhas windows selga.Kas vana säilitamisega või ilma.
          Vs: win7 probleem
          Suur tänu ideede eest, biose "optimized default" kõrvaldas vea, ning rohkem näppida ei soovi.
            Vs: win7 probleem
            Paigaldasid uue OS-i, või hakkas vana korrektselt käima?
            7 peaks jah, raua muutuste suhtes muidu leplikum olema kui eelmised Win`id.
              Vs: win7 probleem
              Win jäi vana, lihtsalt protsessori vahetus jäi biosega kooskõlastamata.
