Arvuti Ordi viskas eile end välja ja ena ei saagi sisse lülitada. Ette tuleb: Stop: c0000218 registry file failure, the registry cannot load the hive /System roat/sustem 32/config/SOFTWARE on its log n alternate. It is corrupt, absent, or not writable. Beginning dump of physical memory dumping physical memory to disk.
Mis viga võiks olla?
