pic16f84a probleem
  • brand11
    • 09/2002
    • 595
    pic16f84a probleem
    pic ei taha siis k2ivituda ei mikroBasicu testprogega ega ka millegi muuga...
    bas siis siin:
    program Led_blinking
    main:
    TRISB = 0 ' configure pins of portb as output
    PORTB = %11111111 ' turn ON diodes on portb
    delay_ms(1000) ' wait for 1 second
    PORTB = %00000000 ' turn OFF diodes on portb
    goto main ' endless loop
    end
    hex faili peale k6rvetades ei ilmne mingeid probleeme kuid toite taha lylitamisel led ainult p6leb...kas viga v6ib olla selles et pic ise vigane?
  • brand11
    • 09/2002
    • 595
    skeem siin...ainult et 15 ja 16 jala vahel 4MHz kvartsminu
    • brand11
      • 09/2002
      • 595
      sain selle t88le aga nyyd on mul uus mure...proovisin oma pici lcdga(1x16 HD44780)programmijupp siin
      ' microcontroller P16F628
      ' Project LCD_demo
      ' This project is designed to work with PIC 16F628
      ' with minor adjustments, it should work with any other PIC MCU
      ' This code demonstrates displaying text on LCD (4 bit intrface)
      ' and use of LCD library procedures and functions.
      program LCD_demo
      dim txt as char[17]
      main:
      PORTB = 0 ' intial value for portb
      TRISB = 0 ' designate portb as output
      Lcd_Init(PORTB) ' initialize LCD connected to portb
      Lcd_Cmd(PORTB, LCD_CLEAR) ' send command to LCD "clear display"
      LCD_Cmd(PORTB, LCD_CURSOR_OFF) ' send command cursor off
      txt = "mikroElektronika" ' write string to txt
      LCD_Out(PORTB,2,1,txt) ' print txt to LCD, 2nd row, 1st column
      end.
      kui panna row asemele 1 siis n2en millegip2rast ainult lcd 8 esimest m2rki ja kui panna row asemele 2 siis n2en 8 viimast m2rki...kas viga on lcd's?
      panen siia ka asja asm faili...
      asm fail
      • felch
        • 01/2002
        • 8727
        LCD ongi jaotatud mitmeks 8-märgiliseks osadispleiks. Pikema teksti puhul peab kogu aeg jälgima viimast pos.-i ja kui >8, peab saatma displeile käsu minna üle järgmisele reale (2x16 puhul reale 3) ja siis jälle datat saatma.
        • raivo
          • 01/2002
          • 1005
          mälujaotus söltub jah lcd-st.
          enamasti on see nii:
          ma arvan et picbasicu soft toetab ka 1 realist LCDd, aga pead defineerima eelnevalt :
          DEFINE LCD_LINES 1 'Number lines on LCD
