MPLAB IDE ja PIC Tutorial
    Otsisin välja oma vana robotiprojekti ja üle pika aja leidsin aega vähe PICutada. Oma paar kolm tundi läks, et olemasolevast vanast koodist taas aru saada (NB! Selgitustel on ka iseenda jaoks ja iseenda programmis suur mõte!!! ) Aga probleem nüüd selline, et Taimerid ei taha interrupte tekitada... Igaks juhuks panin kogu faili siia, natuke jurakas ta ju on, kuid ehk hakkab midagi seal silma, kus ise ei kahtlustagi...
    Kood:
      #include "p16f876a.inc"
      LIST P=16f876a
      errorlevel   -302  &#59;Suppress bank warning
      __CONFIG _WDT_OFF & _XT_OSC & _CP_OFF & _LVP_OFF
      cblock	0x20  &#59; local variables, only in bank 0
     R_Motor 	&#59; temp address to know the motor position
     L_Motor
     COUNTER1 &#59; Counters for
     COUNTER2 &#59; Stepper direction
     MOTOR_DIR1 &#59; Temp files for motor direction
     MOTOR_DIR2 &#59;
     W_Temp 	&#59;
     S_Temp 	&#59;
     TempL 	&#59;
     TempR 	&#59;
     Right_Speed &#59;
     Left_Speed
    	endc
    ;*            Makrod   	*
    BANK0 MACRO
     BCF	STATUS,RP1
     BCF	STATUS,RP0
     ENDM
    BANK1 MACRO
     BCF	STATUS,RP1
     BSF	STATUS,RP0
     ENDM
    BANK2 MACRO
     BSF	STATUS,RP1
     BCF	STATUS,RP0
     ENDM
    BANK3 MACRO
     BSF	STATUS,RP1
     BSF	STATUS,RP0
     ENDM
    DRIVE	macro	mdir1, mdir2, rspd, lspd
    	movlw	mdir1
    	movwf	MOTOR_DIR1
    	movlw	mdir2
    	movwf	MOTOR_DIR2
    	movlw	rspd
    	movwf	Right_Speed
    	movlw	lspd
    	movwf	Left_Speed
    	endm
    ;**** Hakkame aga pihta **************
    	org 0x00	&#59; reset vector
    	goto	Start
    ;	Interruptid
    Interrupt org 0x04 &#59; interrupt vector
      movwf	W_Temp &#59; salvestame hetkeollukorra
      swapf	STATUS,W
      movwf	S_Temp
      bcf STATUS,RP0
    Disable_Int
      bcf INTCON,GIE	&#59; keelame globaalselt ära interruptid
      btfsc	INTCON,T0IF	&#59; kas TIMER0 lipp on püsti?
      goto	Right_Step	&#59; On küll!
      btfsc	PIR1,TMR2IF	&#59; kas TIMER2 lipp on püsti?
      goto	Left_Step	&#59; On küll!
    Pop
      swapf	S_Temp,W	&#59; taastame enneinterruptiaegse olukorra
      movwf	STATUS
      swapf	W_Temp,f
      swapf	W_Temp,w
      retfie
    ;****The main program*****
    Start
    	CLRF	PORTB &#59; Initialize Port B
    	CLRW
    	BANK1  &#59; Select Register Bank 1
    	MOVWF	TRISB &#59; Set B to all outputs
    	CLRF TMR0 	&#59; Clear Timer0 register
    	CLRF INTCON 	&#59; Disable interrupts and clear T0IF
    	BANK1
    	MOVLW 0xC3 	&#59; PortB pull-ups are disabled,
    	MOVWF OPTION_REG &#59; Interrupt on rising edge of RB0
       &#59; Timer0 increment from internal clock
       &#59; with a prescaler of 1:16.
    	BANK0
    	CLRF T2CON 	&#59; Stop Timer2, Prescaler = 1:1,
       &#59; Postscaler = 1:1
    	CLRF TMR2 	&#59; Clear Timer2 register
    	BANK1
    	CLRF PIE1 	&#59; Disable peripheral interrupts
    	BANK0
    	CLRF PIR1 	&#59; Clear peripheral interrupts Flags
    	MOVLW 0x72 	&#59; Postscaler = 1:15, Prescaler = 1:16
    	MOVWF T2CON 	&#59; Timer2 is off
    	BSF T2CON, TMR2ON &#59; Timer2 starts to increment
    	BSF INTCON, T0IE &#59; Enable TMR0 interrupt
    	BSF INTCON, GIE &#59; Enable all interrupts
    MAIN
     DRIVE 1, 0, 0xC8, 0xC8
     goto MAIN
    ;	Mootorite astumised
    Right_Step
    	movlw	Right_Speed	&#59; loeme etteantud ajaväärtuse TIMER0 jaoks
    	movwf	TMR0 &#59; omistame väärtuse TIMER0-le
    	bcf INTCON,T0IF	&#59; nullime TIMER0 interrupt flägi
    	swapf	PORTB,w &#59; loeme mootori seisu, keerame tulemuse ringi
    	andlw	b'11110000'	&#59; nullime selle mootori bitid, teisi ei puudu
    	movwf TempL 	&#59; seivime
    	call	R_Motor_Pos	&#59; vaatame, mis on mootori A uus seis
    	movf R_Motor,W &#59; Loeme mootori A uue seisu
    	iorwf TempL,F &#59; valmis juhtsõna mootorite jaoks
    	movf TempL,W
    	movwf PORTB &#59; tulemus mootorite porti
    	return
    Left_Step
    	movf	Left_Speed,w&#59; loeme etteantud ajaväärtuse TIMER2 jaoks
    	movwf	TMR2 &#59; omistame väärtuse TIMER2-le
    	bcf PIR1,TMR2IF	&#59; nullime TIMER2 interrupt flägi
    	movf	PORTB,w &#59; loeme mootori seisu
    	movwf TempR 	&#59; seivime
    	call	L_Motor_Pos	&#59; vaatame, mis on mootori B uus seis
    	movf L_Motor,W &#59; loeme mootori B uue seisu
    	iorwf TempR,F &#59; valmis juhtsõna mootorite jaoks
    	movf TempR,W
    	return
    R_Motor_Pos:
    	btfsc	MOTOR_DIR1,0&#59; Kas liigume edasi või tagasi?
    	incf	COUNTER1,f	&#59; Liigume edasi!
    	btfss	MOTOR_DIR1,0
    	decf	COUNTER1,f	&#59; Liigume tagasi!
    	movf	COUNTER1,w
    	call	GET_R_MOTOR_POSITION&#59; pöördume tabeli poole
    	movwf	R_Motor &#59; salvestame tulemuse faili
    	return
    GET_R_MOTOR_POSITION:
      andlw  b'00000111'
      addwf  PCL,F
      retlw  0x8
      retlw  0xA
      retlw  0x2
      retlw  0x6
      retlw  0x4
      retlw  0x5
      retlw  0x1
      retlw  0x9
    L_Motor_Pos
    	btfsc	MOTOR_DIR2,0&#59; Kas liigume edasi või tagasi?
    	incf	COUNTER2,f	&#59;Liigume edasi!
    	btfss	MOTOR_DIR2,0
    	decf	COUNTER2,f	&#59;Liigume tagasi!
    	movf	COUNTER2,w
    	call	GET_L_MOTOR_POSITION&#59; pöördume tabeli poole
    	movwf	L_Motor &#59; salvestame tulemuse faili
    	return
    GET_L_MOTOR_POSITION:
      andlw  b'00000111'
      addwf  PCL,F
      retlw  0x8
      retlw  0xA
      retlw  0x2
      retlw  0x6
      retlw  0x4
      retlw  0x5
      retlw  0x1
      retlw  0x9
    	END
    Oota! Las ma teen seda natuke paremaks...
      Kui kirjutaks init-isse: bsf INTCON,PEIE
        jah, ning lisaks oleks tore peale interrupti läbiviimist globaalselt kõik interruptid lubada, eriti kui eelnevalt ise ära keelasin
          Ei saa aru, mis talle ei meeldi, kompileerimisel ütleb:
          Kood:
          Error[115]  C:\ELECTRONICS\PROGRAMMING\BOT\BOT.ASM 464 : Duplicate label ("Right_count" or redefining symbol that cannot be redefined)
          Error[115]  C:\ELECTRONICS\PROGRAMMING\BOT\BOT.ASM 471 : Duplicate label ("Left_count" or redefining symbol that cannot be redefined)
          Koodi väljavõtted:
          Kood:
          Disable_Int
            bcf INTCON,GIE
            btfsc	INTCON,T0IF
            call	Right_count
            btfsc	PIR1,TMR2IF
            call	Left_count
          Kood:
          Right_count
           clrf	rcount
           decfsz	rcount,1
           return
           call	Right_Step
           return
          Left_count
           clrf	lcount
           incfsz	lcount,1
           return
           call	Left_Step
           return
            Äkki oled Right_Count'i proge päises defineerinud? Kusagil ta peab olema, muidu sellist viga ei anta. Kui kasutad incluuditavaid mooduleid, vaata ka nende tekst üle...või muuda lihtsalt oma koodis märgendi nime (kasvõi Parem_count, Vasak_count).
              olin jah defineerinud päises. :P Aga see selleks, nüüd uus mure.
              Kood:
              CORE-E0001: Stack over flow error occurred from instruction at 0x000060
              Nagu ma aru saan, pean vähendama üksteise "sees" olevaid CALL ja GOTO funktsioone? Üritama asja kuidagi muudmoodi kombineerida?
                CALL on see, mis stacki ruumi kulutab. GOTO mitte. Kas asi tekib katkestusest?
                  jah, kusjuures, kui lasen simu käima, siis mingi aeg jookseb ilusasti ja siis viskab selle teate ette. Peale seda, kohe kui lasen uuesti käima, siis karjub sama.
                    Otsi üles worst-case alamprogede väljakutsumiste tee ja loe tarbitava stacki sügavus kokku. Tee järeldused, paranda koodi.
                    Omal olid samad mured ühe vidinaga kuid õnnestus tõsta terve "koodipuu" GOTO käskude alla. Midagi pole teha, vaid 18Fxxx-l ja vingematel on suurem stack.
                    PS. Jälgi ka PCLATH'i kui kood peaks üle 0x7FF minema (16F88 ja muude hästi varustet PICide puhul, aadressi vamńimat bitti pead sel juhul ise väänama )
                      ok, alustasin asja nullist, tundus lihtsam.
                      Probleem jälle interruptidega, ei taha toimida nimelt... võrdlesin ka vana koodiga, mille siia postitasin aga ei näe viga...
                      Kood:
                      Interrupt  org  0x04    ; interrupt vector
                         movwf   W_TEMP    ;
                         swapf   STATUS,W
                         movwf   S_TEMP
                         bcf      STATUS,RP0
                      Disable_Int
                         btfsc   INTCON,T0IF;
                         goto      Step  &#59;
                      Pop
                         swapf S_TEMP,W      ;
                         movwf STATUS
                         swapf W_TEMP,f
                         swapf W_TEMP,w
                         retfie
                         #include "Bot.inc"
                      Start
                         CLRF   PORTA        ; Initialize Port A
                         CLRF   PORTB        ; Initialize Port B
                         CLRF   PORTC        ; Initialize Port C
                         CLRW
                         BANK1              ; Select Register Bank 1
                         MOVWF   TRISB        ; Set B to all outputs for stepper control
                         BANK0
                         BANK1
                         MOVLW    0xC7        &#59; PortB pull-ups are disabled,
                         MOVWF    OPTION_REG      ; Interrupt on rising edge of RB0
                                          ; with a prescaler of 1:256.
                         BANK0
                         BSF   INTCON, T0IE    &#59; Enable Timer0 Interrupts
                          BSF INTCON, GIE      ; Enable all interrupts
                         BSF   INTCON, PEIE
                        Elou!
                        Huvitav... mismoodi ei taha toimida?
                        Proovisin... minul toimib.
                        Kui Sa proovisid simulaatoris ja klõpsisid hiirega "step into"
                        siis võtab natuke aega kui TMR0 muutub - Prescaler rate on 1:256.
                        Pane sinna "goto Step" kohale simulaatori katkestus ja käivita "Run".
                        aega kulub 65.5ms
                        parimat soovides,
                        gOb
                        Meie üle nalja ei mõisteta!
                          müstika.... ok eks ma katsetan kodus uuesti. Sest just sedasi ma interrupte olengi proovinud, et panen katkestuse vahele ja lasen käima. Isegi jälgisin samas TIMER0 väärtust ja pausisin iga natukese aja tagant simu, jooksis ludinal üle 255 ja kukkus uuesti nulli, ei mingit interrupti.
                          Aga eks õhtul kontrollin üle uuesti.
                            Pane kursor INT-i algusesse ja ütle "run to cursor". Siis on oht katkestust mitte märgata väiksem. Kui jääb jooksma siis tõesti ei katkestu. Praegune kood töötab ka minu simuga.
                              jah...ei saa aru mida ma eile õhtul tegin et ei toiminud. Täna töötab. :unsure:
