Kood siis selline:
;Softcode For Digital Speedometer
;Made By: Abhishek Jain
;Dated: 25/02/2005
;Including Controller Definetion File
.include "2313def.inc"
;Description
;The connection details are as given in schematic
;LCD is connected to port B and sensor is connected
;to INT 0 pin of MCU
;calculation Details (Formulae Used)
;############For speed measurement#################
;speed = 2*pi*R*3600*clk/time_count*1000*x
;R = radius of the wheel in cm (In this design R=25cm)
;time_count = value of timer counter in b/w
;two successive interrupts
;x = clock prescaler used (in this design x=1024)
;using this we have calculated the equivalent value of
;all the constants (except time_count all other parameters
;are constants)
;sh and sl are binary equivalent of this constant
.equ sh = $56
.equ sl = $49
.equ sht = $57 ;sht = sh + 1
;############For distance measurement################
;After every 100 m the registers holding distance values
;are incremented. For this we have used following formulae
; 2*pi*R*n/100 = 100
;n is the count which signifies that 100 m has been completed
.equ n = $40
;To give useful names to Registers
;##########temporay registers##############
.def temp=r16
.def temp1=r18
.def c1=r22 ;used for speed calculation and for display purpose
.def c2=r4 ;used for speed calculation and for display purpose
.def d1=r5 ;used for speed calculation and for display purpose
.def d2=r6 ;used for speed calculation and for display purpose
.def status=r7 ;holds the value of status register in case of interrupt
;#########Registers used for timing########
.def count_1=r17 ;
.def time_1=r1
.def time_0=r2
;#########Registers used for speed measurement##########
.def sdigit_01=r19
.def sdigit_1=r20 ;holds the binary value of speed
;########Registers used for Distance measurement#########
.def ddigit_01=r8 ;Holds binary value of distance (0.0 to 9.9)
.def ddigit_1=r9 ;Holds binary value of distance (10.0 to 999.9)
.def ddigit_10=r10 ;Holds binary value of distance (1000.0 to 99999.9)
.def dist_count=r13
;#########Registers used for LCD display##########
.def lcd_cmd=r21
.def lcd_dat=r23
.def count=r3
;########Registers used for delays############
.def low_del=r24
.def hi_del=r25
;########Registers used for EEPROM###########
.def eep_reg=r11
.def eep_addr=r12
;r14r15
;Code Segment
.cseg
.org 0
rjmp RESET
.org INT0addr
rjmp IntV0
reti
reti
reti
reti
.org OVF0addr
rjmp TimerV0
reti
reti
reti
reti
.org $000b
;Reset interrupt subroutine
;to be executed on Reset interrupt
RESET:
;#######Initializing Stack Pointer############
ldi temp,RAMEND
out SPL, temp
;#######Initializing I/O Ports################
ldi temp, 0b11111111 ;configure PORT B for all outputs
out DDRB, temp
ldi temp,0
out DDRD,temp
ldi temp,$ff
out PORTD,temp ;configure PORT D for all inputs
;#########Initializing INT 0 interrupt########
ldi temp,$40 ;Enabling INT 0 interrupt
out GIMSK,temp
ldi temp,$03 ;Interrupt on rising edge
out MCUCR,temp
;########Intializing timing process##########
ldi temp,$02
out TIMSK,temp ;Enabling timer overflow interrupt
ldi temp,$05
out TCCR0,temp
ldi temp,$00 ;Initializing Registers
out TCNT0,temp
clr time_0
clr time_1
;#############Initializing registers holding speed############
clr sdigit_1
clr sdigit_01
;#############Initializing registers holding distance############
clr dist_count
clr ddigit_01
clr ddigit_1
clr ddigit_10
rcall eeprom_read
;############Initializing LCD Display##################
rcall init_lcd
rcall init_lcd
rcall hi_delay
;############enabling global mask interrupt enable#########
sei
;Main Part of the Program
main_loop:
rcall dist ;Subroutine to calculate Distance
rcall print_lcd ;Subroutine for LCD Display
rjmp main_loop
;INT 0 ISR
IntV0:
in status,SREG
in time_0,TCNT0
mov time_1,count_1
clr count_1
out TCNT0,count_1
inc dist_count
rcall speed ;Subroutine for speed calculation
out SREG,status
reti
;Timer overflow ISR
TimerV0:
in status,SREG
inc count_1
cpi count_1,sht
brsh timeff
out SREG,status
reti
timeff:
clr count_1
rcall time00
ret
;Calculation of speed
speed:
push d1
push d2
push c1
push c2
ldi temp1,$00
cp time_1,temp1
breq time0
speedq:
clr sdigit_1
ldi temp1,sh
mov c1,temp1
ldi temp1,sl
mov c2,temp1
rjmp speedcal
time0:
cp time_0,temp1
breq time00
rjmp speedq
time00:
clr sdigit_1
clr sdigit_01
pop d1
pop d2
pop c1
pop c2
ret
speedcal:
cp c1,time_1
brsh speed_cal
rjmp speed0
speed_cal:
cp c2,time_0
brsh speed_cal1
cp c1,time_1
breq speed0
rjmp speed_cal2
speed_cal1:
inc sdigit_1
sub c1,time_1
sub c2,time_0
rjmp speedcal
speed_cal2:
inc sdigit_1
sub c1,time_1
sub c2,time_0
dec c1
rjmp speedcal
speed0:
rjmp scal
scal:
mov d1,c1
mov d2,c2
ldi temp1,10
rjmp scal1
scal1:
cpi temp1,1
brne scal2
rjmp scal3
scal2:
dec temp1
add d2,c2
adc d1,c1
rjmp scal1
scal3:
cp d1,time_1
brsh scal4
rjmp speed1
scal4:
cp d2,time_0
brsh scal5
cp d1,time_1
breq speed1
rjmp scal6
scal5:
inc sdigit_01
sub d1,time_1
sub d2,time_0
rjmp scal3
scal6:
inc sdigit_01
sub d1,time_1
sub d2,time_0
dec d1
rjmp scal3
speed1:
pop d1
pop d2
pop c1
pop c2
ret
;Calculation of distance
dist:
ldi temp1,n
cp dist_count,temp1
brsh dist_cal
ret
dist_cal:
clr dist_count
inc ddigit_01
ldi temp,1
mov eep_addr,temp
mov eep_reg,ddigit_01
rcall eeprom_write
ldi temp1,100
cp ddigit_01,temp1
brsh dist_cal1
ret
dist_cal1:
clr ddigit_01
inc ddigit_1
ldi temp,1
mov eep_addr,temp
rcall eeprom_write
ldi temp,2
mov eep_addr,temp
mov eep_reg,ddigit_1
rcall eeprom_write
ldi temp1,100
cp ddigit_1,temp1
brsh dist_cal2
ret
dist_cal2:
clr ddigit_1
inc ddigit_10
ldi temp,1 ;storing data to EEPROM
mov eep_addr,temp
rcall eeprom_write
ldi temp,2
mov eep_addr,temp
rcall eeprom_write
ldi temp,3
mov eep_addr,temp
mov eep_reg,ddigit_10
rcall eeprom_write
ldi temp1,100
cp ddigit_10,temp1
brsh dist_cal3
ret
dist_cal3:
clr dist_count
clr ddigit_01
clr ddigit_1
clr ddigit_10
ret
;Initializes distance registers values to
;previously stored value in EEPROM
eeprom_read:
cli
push temp
ldi temp,1
mov eep_addr, temp
rcall eep_nr
mov ddigit_01, eep_reg
ldi temp,2
mov eep_addr, temp
rcall eep_nr
mov ddigit_1, eep_reg
ldi temp,3
mov eep_addr, temp
rcall eep_nr
mov ddigit_10, eep_reg
pop temp
sei
ret
;Subroutine to read data from eeprom
;eep_addr holds the address of eeprom
;eep_reg holds the data read
eep_nr:
sbic EECR,EERE
rjmp eep_nr
read:
out EEAR, eep_addr
sbi EECR, EERE
nop
nop
in eep_reg, EEDR
ret
;Subroutine to write data to eeprom
;eep_reg holds the data to be written
eeprom_write:
sbic EECR, EEWE
rjmp eeprom_write
write:
out EEAR,eep_addr
out EEDR,eep_reg
cli
sbi EECR,EEMWE
sbi EECR,EEWE
sei
ret
;Init_Lcd: Initializes the 16 X 2 LCD module in 4 bit data
;transfer mode
init_lcd:
ldi lcd_cmd, 3
rcall lcd_low_cmd
rcall hi_delay
ldi lcd_cmd, 3
rcall lcd_low_cmd
rcall low_delay
ldi lcd_cmd, 3
rcall lcd_low_cmd
rcall low_delay
ldi lcd_cmd, $28 ; set 4-bit interface
rcall lcd_all_cmd
ldi lcd_cmd, 8 ; set DDRAM address to 00
rcall lcd_all_cmd
ldi lcd_cmd, $0c
rcall lcd_all_cmd
ldi lcd_cmd, 6
rcall lcd_all_cmd ; mode setting
ret
;Print_Lcd: Prints speed and distance on the LCD display module
print_lcd:
ldi lcd_cmd, $80
rcall lcd_all_cmd
ldi temp, 16
mov count, temp
ldi ZH, high(msg1*2)
ldi ZL, low(msg1*2)
more1:
lpm
mov lcd_dat, r0
rcall lcd_all_dat
adiw ZL, 1
dec count
ldi temp, 0
cp count, temp
brne more1
ldi temp, 16
mov count,temp
ldi lcd_cmd, $c0
rcall lcd_all_cmd
more2:
lpm
mov lcd_dat, r0
rcall lcd_all_dat
adiw ZL, 1
dec count
ldi temp, 0
cp count, temp
brne more2
;###########Binary to BCD conversion######################
clr d2
speeddigit: ;hundredth place value of speed
cpi sdigit_1,100
brsh sdigit_cal
rjmp print1
sdigit_cal:
inc d2
subi sdigit_1,100
rjmp speeddigit
print1:
ldi lcd_cmd,$86
rcall lcd_all_cmd
mov lcd_dat,d2
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
mov c1,sdigit_1
rcall bcd
mov sdigit_1,c1
mov c2,d1
ldi lcd_cmd,$87 ;tenths place value of speed
rcall lcd_all_cmd
mov lcd_dat,c2
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
ldi lcd_cmd,$88 ;units place value of speed
rcall lcd_all_cmd
andi sdigit_1,$0f
mov lcd_dat,sdigit_1
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
ldi lcd_cmd,$8a ;decimal place value of speed
rcall lcd_all_cmd
andi sdigit_01,$0f
mov lcd_dat,sdigit_01
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
;##################prints distance#############################
mov c1,ddigit_10
rcall bcd
ldi lcd_cmd,$c5 ;ten thousandth place of distance
rcall lcd_all_cmd
rcall low_delay
mov lcd_dat,d1
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
ldi lcd_cmd,$c6 ;thousandth place of distance
rcall lcd_all_cmd
rcall low_delay
mov lcd_dat,c1
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
mov c1,ddigit_1
rcall bcd
ldi lcd_cmd,$c7 ;hundredth place value of distance
rcall lcd_all_cmd
rcall low_delay
mov lcd_dat,d1
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
ldi lcd_cmd,$c8 ;Tenth place value of distance
rcall lcd_all_cmd
rcall low_delay
mov lcd_dat,c1
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
mov c1,ddigit_01
rcall bcd
ldi lcd_cmd,$c9 ;Units place value of distance
rcall lcd_all_cmd
rcall low_delay
mov lcd_dat,d1
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
ldi lcd_cmd,$cb ;decimal place of distance
rcall lcd_all_cmd
rcall low_delay
mov lcd_dat,c1
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
ret
;Binary to BCD conversion
bcd:
clr d1
bcddigit:
cpi c1,10
brsh bcd_cal
ret
bcd_cal:
inc d1
subi c1,10
rjmp bcddigit
;Low_Delay: A 250 us delay
low_delay:
push low_del
push hi_del
ldi low_del, 20
ld_hi:
ldi hi_del, 10
loop_in:
dec hi_del
cpi hi_del, 0
brne loop_in
dec low_del
cpi low_del, 0
brne ld_hi
pop hi_del
pop low_del
ret
;Hi_Delay: A 5 ms delay
hi_delay:
ldi low_del, 25
more_call:
rcall low_delay
dec low_del
cpi low_del, 0
brne more_call
ret
;Lcd_Low_Cmd: Sends a command to higher 4 bits of the LCD.
;The command nibble must be in the lower nibble of the
;variable 'lcd_cmd'
lcd_low_cmd:
mov temp, lcd_cmd
lsl temp
lsl temp
lsl temp
lsl temp
andi temp, $f0
out PORTB, temp
ori temp, $08
out PORTB, temp
andi temp, $f7
out PORTB, temp
ret
;Lcd_All_Cmd: sends an 8 bit command to the LCD
lcd_all_cmd:
push lcd_cmd
lsr lcd_cmd
lsr lcd_cmd
lsr lcd_cmd
lsr lcd_cmd
rcall lcd_low_cmd
pop lcd_cmd
andi lcd_cmd, $0f
rcall lcd_low_cmd
rcall low_delay
ret
;Lcd_All_Dat: Sends a data byte to the LCD. The data byte
;is stored in variable 'lcd_dat'
lcd_all_dat:
push lcd_dat
lsr lcd_dat
lsr lcd_dat
lsr lcd_dat
lsr lcd_dat
andi lcd_dat, $0f
rcall lcdlowdat
pop lcd_dat
andi lcd_dat, $0f
rcall lcdlowdat
rcall low_delay
ret
;Lcd_Low_Dat: Sends a data nibble to higher 4 bits of the
;LCD. The data nibble must be in the lower nibble of the
;variable 'lcd_dat'
lcdlowdat:
mov temp, lcd_dat
lsl temp
lsl temp
lsl temp
lsl temp
andi temp, $f0
ori temp, $04
out PORTB, temp
ori temp, $08
out PORTB, temp
andi temp, $f7
out PORTB, temp
ret
;Message #1
msg1: .db "SPEED= . Km/hrDIST= . Km "
; 12345678123456781234567812345678
Tegu on spidomeetriga, mis töötab avr-i pealt. Spido arvutab kiiruse ja läbitud teepikkuse... Hetkel on kood seadistatud liikurile, mille ratta raadius on 25cm... Mida ma koodis muutma peaksin, et spidomeeter 19cm raadiusega rattaga ei valetaks?
;Dated: 25/02/2005
;Description
;are constants)
.equ sh = $56
.equ sl = $49
.equ n = $40
.def temp=r16
.def temp1=r18
.def count_1=r17 ;
.def time_1=r1
.def time_0=r2
.def sdigit_01=r19
.def dist_count=r13
.def lcd_cmd=r21
.def lcd_dat=r23
.def count=r3
.def low_del=r24
.def hi_del=r25
.def eep_reg=r11
.def eep_addr=r12
;r14r15
;Code Segment
.cseg
.org 0
rjmp RESET
.org INT0addr
rjmp IntV0
reti
reti
reti
reti
.org OVF0addr
rjmp TimerV0
reti
reti
reti
reti
.org $000b
RESET:
ldi temp,RAMEND
out SPL, temp
out DDRB, temp
ldi temp,0
out DDRD,temp
ldi temp,$ff
out GIMSK,temp
out MCUCR,temp
ldi temp,$02
ldi temp,$05
out TCCR0,temp
out TCNT0,temp
clr time_0
clr time_1
clr sdigit_1
clr sdigit_01
clr dist_count
clr ddigit_01
clr ddigit_1
clr ddigit_10
rcall eeprom_read
rcall init_lcd
rcall init_lcd
rcall hi_delay
sei
main_loop:
rjmp main_loop
;INT 0 ISR
IntV0:
in status,SREG
in time_0,TCNT0
mov time_1,count_1
clr count_1
out TCNT0,count_1
inc dist_count
out SREG,status
reti
;Timer overflow ISR
TimerV0:
in status,SREG
inc count_1
cpi count_1,sht
brsh timeff
out SREG,status
reti
timeff:
clr count_1
rcall time00
ret
speed:
push d1
push d2
push c1
push c2
ldi temp1,$00
cp time_1,temp1
breq time0
speedq:
clr sdigit_1
ldi temp1,sh
mov c1,temp1
ldi temp1,sl
mov c2,temp1
rjmp speedcal
time0:
cp time_0,temp1
breq time00
rjmp speedq
time00:
clr sdigit_1
clr sdigit_01
pop d1
pop d2
pop c1
pop c2
ret
speedcal:
cp c1,time_1
brsh speed_cal
rjmp speed0
speed_cal:
cp c2,time_0
brsh speed_cal1
cp c1,time_1
breq speed0
rjmp speed_cal2
speed_cal1:
inc sdigit_1
sub c1,time_1
sub c2,time_0
rjmp speedcal
speed_cal2:
inc sdigit_1
sub c1,time_1
sub c2,time_0
dec c1
rjmp speedcal
speed0:
rjmp scal
scal:
mov d1,c1
mov d2,c2
ldi temp1,10
rjmp scal1
scal1:
cpi temp1,1
brne scal2
rjmp scal3
scal2:
dec temp1
add d2,c2
adc d1,c1
rjmp scal1
scal3:
cp d1,time_1
brsh scal4
rjmp speed1
scal4:
cp d2,time_0
brsh scal5
cp d1,time_1
breq speed1
rjmp scal6
scal5:
inc sdigit_01
sub d1,time_1
sub d2,time_0
rjmp scal3
scal6:
inc sdigit_01
sub d1,time_1
sub d2,time_0
dec d1
rjmp scal3
speed1:
pop d1
pop d2
pop c1
pop c2
ret
dist:
ldi temp1,n
cp dist_count,temp1
brsh dist_cal
ret
dist_cal:
clr dist_count
inc ddigit_01
ldi temp,1
mov eep_addr,temp
rcall eeprom_write
ldi temp1,100
cp ddigit_01,temp1
brsh dist_cal1
ret
dist_cal1:
clr ddigit_01
inc ddigit_1
ldi temp,1
mov eep_addr,temp
rcall eeprom_write
ldi temp,2
mov eep_addr,temp
rcall eeprom_write
ldi temp1,100
cp ddigit_1,temp1
brsh dist_cal2
ret
dist_cal2:
clr ddigit_1
inc ddigit_10
mov eep_addr,temp
rcall eeprom_write
ldi temp,2
mov eep_addr,temp
rcall eeprom_write
ldi temp,3
mov eep_addr,temp
rcall eeprom_write
ldi temp1,100
cp ddigit_10,temp1
brsh dist_cal3
ret
dist_cal3:
clr dist_count
clr ddigit_01
clr ddigit_1
clr ddigit_10
ret
eeprom_read:
cli
push temp
ldi temp,1
mov eep_addr, temp
rcall eep_nr
ldi temp,2
mov eep_addr, temp
rcall eep_nr
ldi temp,3
mov eep_addr, temp
rcall eep_nr
pop temp
sei
ret
eep_nr:
sbic EECR,EERE
rjmp eep_nr
read:
out EEAR, eep_addr
sbi EECR, EERE
nop
nop
in eep_reg, EEDR
ret
eeprom_write:
sbic EECR, EEWE
rjmp eeprom_write
write:
out EEAR,eep_addr
out EEDR,eep_reg
cli
sbi EECR,EEMWE
sbi EECR,EEWE
sei
ret
;transfer mode
init_lcd:
ldi lcd_cmd, 3
rcall lcd_low_cmd
rcall hi_delay
ldi lcd_cmd, 3
rcall lcd_low_cmd
rcall low_delay
ldi lcd_cmd, 3
rcall lcd_low_cmd
rcall low_delay
rcall lcd_all_cmd
rcall lcd_all_cmd
ldi lcd_cmd, $0c
rcall lcd_all_cmd
ldi lcd_cmd, 6
ret
print_lcd:
ldi lcd_cmd, $80
rcall lcd_all_cmd
ldi temp, 16
mov count, temp
ldi ZL, low(msg1*2)
more1:
lpm
mov lcd_dat, r0
rcall lcd_all_dat
adiw ZL, 1
dec count
ldi temp, 0
cp count, temp
brne more1
ldi temp, 16
mov count,temp
ldi lcd_cmd, $c0
rcall lcd_all_cmd
more2:
lpm
mov lcd_dat, r0
rcall lcd_all_dat
adiw ZL, 1
dec count
ldi temp, 0
cp count, temp
brne more2
clr d2
cpi sdigit_1,100
brsh sdigit_cal
rjmp print1
sdigit_cal:
inc d2
subi sdigit_1,100
rjmp speeddigit
print1:
ldi lcd_cmd,$86
rcall lcd_all_cmd
mov lcd_dat,d2
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
mov c1,sdigit_1
rcall bcd
mov sdigit_1,c1
mov c2,d1
rcall lcd_all_cmd
mov lcd_dat,c2
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
rcall lcd_all_cmd
andi sdigit_1,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
rcall lcd_all_cmd
andi sdigit_01,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
mov c1,ddigit_10
rcall bcd
rcall lcd_all_cmd
rcall low_delay
mov lcd_dat,d1
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
rcall lcd_all_cmd
rcall low_delay
mov lcd_dat,c1
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
mov c1,ddigit_1
rcall bcd
rcall lcd_all_cmd
rcall low_delay
mov lcd_dat,d1
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
rcall lcd_all_cmd
rcall low_delay
mov lcd_dat,c1
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
mov c1,ddigit_01
rcall bcd
rcall lcd_all_cmd
rcall low_delay
mov lcd_dat,d1
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
rcall lcd_all_cmd
rcall low_delay
mov lcd_dat,c1
andi lcd_dat,$0f
ori lcd_dat,$30
rcall lcd_all_dat
rcall low_delay
ret
bcd:
clr d1
bcddigit:
cpi c1,10
brsh bcd_cal
ret
bcd_cal:
inc d1
subi c1,10
rjmp bcddigit
low_delay:
push low_del
push hi_del
ldi low_del, 20
ld_hi:
ldi hi_del, 10
loop_in:
dec hi_del
cpi hi_del, 0
brne loop_in
dec low_del
cpi low_del, 0
brne ld_hi
pop hi_del
pop low_del
ret
hi_delay:
ldi low_del, 25
more_call:
rcall low_delay
dec low_del
cpi low_del, 0
brne more_call
ret
;variable 'lcd_cmd'
lcd_low_cmd:
mov temp, lcd_cmd
lsl temp
lsl temp
lsl temp
lsl temp
andi temp, $f0
out PORTB, temp
ori temp, $08
out PORTB, temp
andi temp, $f7
out PORTB, temp
ret
lcd_all_cmd:
push lcd_cmd
lsr lcd_cmd
lsr lcd_cmd
lsr lcd_cmd
lsr lcd_cmd
rcall lcd_low_cmd
pop lcd_cmd
andi lcd_cmd, $0f
rcall lcd_low_cmd
rcall low_delay
ret
lcd_all_dat:
push lcd_dat
lsr lcd_dat
lsr lcd_dat
lsr lcd_dat
lsr lcd_dat
andi lcd_dat, $0f
rcall lcdlowdat
pop lcd_dat
andi lcd_dat, $0f
rcall lcdlowdat
rcall low_delay
ret
;variable 'lcd_dat'
lcdlowdat:
mov temp, lcd_dat
lsl temp
lsl temp
lsl temp
lsl temp
andi temp, $f0
ori temp, $04
out PORTB, temp
ori temp, $08
out PORTB, temp
andi temp, $f7
out PORTB, temp
ret
;Message #1
