Vs: AVR-programmaatorid. Kõige odavam?
Sellel peaks ju standardpesa olema?
-------------- Build: Debug in mpguu (compiler: GNU AVR GCC Compiler)--------------- avr-gcc.exe -Wall -mmcu=atmega8 -DF_CPU=16000000UL -g -IC:\WinAVR-20100110\avr\include -c fuse.c -o obj\Debug\fuse.o avr-gcc.exe -Wall -mmcu=atmega8 -DF_CPU=16000000UL -g -IC:\WinAVR-20100110\avr\include -c main.c -o obj\Debug\main.o avr-g++.exe -LC:\WinAVR-20100110\avr\lib -o bin\Debug\mpguu.elf obj\Debug\fuse.o obj\Debug\main.o -mmcu=atmega8 -Wl,-Map=bin\Debug\mpguu.map,--cref Output size is 3.26 KB Running project post-build steps cmd /c "avr-objdump -h -S bin\Debug\mpguu.elf > bin\Debug\mpguu.lss" avr-objcopy -R .eeprom -R .fuse -R .lock -R .signature -O ihex bin\Debug\mpguu.elf bin\Debug\mpguu.hex avr-objcopy --no-change-warnings -j .eeprom --change-section-lma .eeprom=0 -O ihex bin\Debug\mpguu.elf bin\Debug\mpguu.eep avr-objcopy --no-change-warnings -j .lock --change-section-lma .lock=0 -O ihex bin\Debug\mpguu.elf bin\Debug\mpguu.lock avr-objcopy --no-change-warnings -j .signature --change-section-lma .signature=0 -O ihex bin\Debug\mpguu.elf bin\Debug\mpguu.sig avr-objcopy --no-change-warnings -j .fuse --change-section-lma .fuse=0 -O ihex bin\Debug\mpguu.elf bin\Debug\mpguu.fuse srec_cat bin\Debug\mpguu.fuse -Intel -crop 0x00 0x01 -offset 0x00 -O bin\Debug\mpguu.lfs -Intel srec_cat bin\Debug\mpguu.fuse -Intel -crop 0x01 0x02 -offset -0x01 -O bin\Debug\mpguu.hfs -Intel Process terminated with status 0 (0 minutes, 2 seconds) 0 errors, 0 warnings (0 minutes, 2 seconds)
Binary sketch size: 17,178 bytes (of a 32,256 byte maximum) avrdude: warning: cannot set sck period. please check for usbasp firmware update. avrdude: Expected signature for ATMEGA328P is 1E 95 0F Double check chip, or use -F to override this check.
