Tahan siis kloonida audes 017 kõlareid. Elemendid olemas, nüüd läheb vaja filtreid ja takisteid. Kahjuks ei leia neid juppe tevalost, äkki aitaksite otsida
jupid siis järgmised:
L1 = 2.9 mH, (wire d=0.9 mm)
L2 = 1.14 mH, (air-core, wire d=0.6 mm)
L3 = 0.6 mH, (air-core, wire d=0.5 mm)
L4 = 0.3 mH, (air-core, wire d=0.5 mm)
L5 = 0.12 mH, (air-core, wire d=0.5 mm)
C1 = 22 uF/50 VAC
C2 = 6.8 uF MKT
C3 = 15 uF/35 VAC
C4 = 3.3 uF MKT
C5 = 2.2 uF MKT
C6 = 2.2 uF MKT
R1 = 5.1 Ohm, 10 W
R2 = 1.5 Ohm, 10 W
R3 = 4.3 Ohm, 7 W
http://web.archive.org/web/20020812223149/.../kit/kit017.htm
C1 = 22 uF/50 VAC
C2 = 6.8 uF MKT
C3 = 15 uF/35 VAC
C4 = 3.3 uF MKT
C5 = 2.2 uF MKT
C6 = 2.2 uF MKT
R1 = 5.1 Ohm, 10 W
R2 = 1.5 Ohm, 10 W
R3 = 4.3 Ohm, 7 W
