Paistab, et mingi suurem jama neil?
Yahoo surnud?
Vs: Yahoo surnud?
Töötab-töötab. Või mida see "minul mitte" täpsemalt tähendab?
Võtad http://nmap.org/download.html + http://www.winpcap.org/install/default.htm ja siis selles sitikmustas aknas annad käsu...
nping --tr --tcp -p 443 yahoo.com
Kaugele päring läheb?
Kood:[B]SENT[/B] (0.2810s) TCP 192.168.1.65:25807 > [B]206.190.36.45:443[/B] S ttl=1 RCVD (0.3590s) ICMP [192.168.1.254 > 192.168.1.65 TTL=0 during transit SENT (1.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=2 RCVD (1.3440s) ICMP [90.190.184.2 > 192.168.1.65 TTL=0 during transit SENT (2.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=3 RCVD (2.3280s) ICMP [90.190.134.112 > 192.168.1.65 TTL=0 during transit SENT (3.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=4 RCVD (3.3590s) ICMP [194.126.123.8 > 192.168.1.65 TTL=0 during transit SENT (4.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=5 RCVD (4.3750s) ICMP [194.126.123.62 > 192.168.1.65 TTL=0 during transit SENT (5.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=6 RCVD (5.4060s) ICMP [195.66.224.129 > 192.168.1.65 TTL=0 during transit SENT (6.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=7 RCVD (6.4380s) ICMP [66.196.65.13 > 192.168.1.65 TTL=0 during transit SENT (7.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=8 RCVD (7.4380s) ICMP [216.115.100.92 > 192.168.1.65 TTL=0 during transit SENT (8.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=9 RCVD (8.4840s) ICMP [216.115.101.145 > 192.168.1.65 TTL=0 during transit SENT (9.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=10 RCVD (9.5310s) ICMP [216.115.96.121 > 192.168.1.65 TTL=0 during transit SENT (10.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=11 RCVD (10.5160s) ICMP [216.115.96.122 > 192.168.1.65 TTL=0 during transit SENT (11.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=12 RCVD (11.5160s) ICMP [66.196.67.5 > 192.168.1.65 TTL=0 during transit SENT (12.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=13 RCVD (12.5160s) ICMP [98.137.31.135 > 192.168.1.65 TTL=0 during transit SENT (13.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=14 RCVD (13.5160s) ICMP [98.137.31.184 > 192.168.1.65 TTL=0 during transit SENT (14.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=15 RCVD (14.5160s) ICMP [206.190.32.23 > 192.168.1.65 TTL=0 during transit SENT (15.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=16 [B]RCVD[/B] (15.5160s) TCP [B]206.190.36.45:443[/B] > 192.168.1.65:25807 [B]SA[/B] ttl=110
Vs: Yahoo surnud?
http://www.downforeveryoneorjustme.com on väga hea koht sellise probleemi uurimise alustamiseks.
Vs: Yahoo surnud?
Esmalt postitatud etsv56 poolt Vaata postitustPole kunagi kasutanud, kas see on mingi otsingumootor.
(Sinna aknasse tuleb domeeninimi kirjutada, nt elfafoorum.eu, ja kui sait on serveris või suure välisühenduse tagant maas, siis saab ka vastava teate ega pea oma arvutit kahtlustama.)
Vs: Yahoo surnud?
Esmalt postitatud A.R. poolt Vaata postitust...
Aga reaalselt leitakse Yahoo.
Tuleb Õigsti valetada, nagu kunagi õpetas Tammsaare.
Seda, et Sinu arvutis Yahoo tegelikult avaneb, see kontrollileht ju ei tea. See kontrollib vaid seda, kas sait on serveris üleval või maas, muud midagi. Kas Yahoo Sinu arvutis avaneb või ei avane, näeb kasutaja ise ning teeb sellest (loogilise) järelduse.
Vs: Yahoo surnud?
Esmalt postitatud Scott poolt Vaata postitustOot, mida siis valetatakse?
Mis vahet on sellega kui nimi on tavaaknas?
JavaScripis otsing ei ole targem.
It's just you. http://altavista.com is up. on VALE väide
Valetamine on ka see et Yahoo on oma nime sokutanud tunduvalt asjalikuma otsingumootori asemele.
Kas müüdi või vahetati aga otsing on nüüd hulga viletsam.
Vs: Yahoo surnud?
Esmalt postitatud A.R. poolt Vaata postitustIt's just you. http://altavista.com is up. on VALE väide
Siin lisaks muude suletavate teenuste andmed.
Vs: Yahoo surnud?
Kui saia asemel sõnnikut pakkuda siis oled sa kalorid kätte saanud.
Seega tehniliselt võttes oled söönud.
AltaVista oli tehniliselt arenenud otsingumootor.
Selles ongi kurbloolisus.
_________________________
Aga kui kasutada neid "mootoreid, ka foorumi oma" eelotsinguks?
Lasta kõik saadu salvestada ja siis teha sealt täpisotsing.
Seda on igaühel võimalik kirjutada oma arvutis ja
saad täpselt see mida tahad.
