Raadiolevi AM jaamad
    Saade 1557 kHz-l on Radio Lenta - www.lentaonline.com Õhtul jätkus edastus peale 00.00 - i. Saated oli ka hommikul 7 ja 8 vahel ja ka praegu 16.30 paiku on Minski Kiwil näha saatja eetrisolekut.Ülekanne on ka YouTubes.
    Peab kuulama, kas kell 19 algab Raadio Varssavi saade algul tund poola ja siis valgevene keeles.
    Nii võeti 1386-lt koormust maha.
    1557 kHz saatja kostis ka vanasti Sitkunaist väga hästi.
    viimati muutis kasutaja swl; 05 August 2022, 16:44.
      Hans Knot kirjutab mediumwave.info-s.
      The transmitter used in Lithuania is the Nautel RX50 which was previously used by Big L on AM 1395 kHz from Trintelhaven in the Netherlands, in an attempt to reach a daytime audience in England. Later this transmitter was used on 1008 kHz to broadcast the religious station Groot Nieuws Radio. Since the 1008 kHz was closed down, the transmitter was stored in the Netherlands.
      The past few weeks a lot of work was done to get the full 50 kilowatts on the air on AM 1557. This also required a new antenna design.
      The results are phenomenal. The signal on AM 1557 can be received well at night throughout Europe. There is a strong night signal in cities like Saint-Petersburg, Moscow and Minsk and it also covers the whole territory of the Ukraine.
      Even on Russia’s border with Norway in the Arctic, the signal is still quite good, as well as in Novosibirsk, which is some 1,500 kilometres from the transmitter site.
      Hollandi keelsed saated kostsid 1008 kHz-l tugevalt, kuigi saatja oli natuke tugevamana vist märgitud. Igati tore, et saatja oli alles ja kusagil veel ära kulus. Seega Sitkunais ka midagi antenni juures ümber tehtud.
      Paistab, et vähemalt praegu teiste jaamade nn. välissaateid sellel sagedusel ei edastata.
        Tänaseks on välja kuulutatud RAI edastuse lõpetamine kesklainel-meie asukohas siis sagedused 658 ja 900 kHz.
        ​​​​​​Õhtul kella 21 - 22 paiku on kuulda India Raadio välissaadetet urdu keeles 1071 kHz. Kosta on ka Iraani saatja.
        1053 kHz R. Maria saatja Sankt-Peterburgist on uuesti käivitatud.
        Malajami keelne saade Emiraatidest on taas vahetanud sagedust ja olenevalt levist ajuti kostab sagedusel 1476 kHz.
        Hommikul 7 paiku on 60 mb kuulda 4885 ja 4985 kHz Brasiilia jaamu ja 5025 ja 5040 kHz Kuuba programme.
        Kuuldavus on nõrgapoolne aga siiski midagi kostab ja mõnikord võib ka levi parem olla.
          Hommikul nii 6 ja 8 vahel on kuulda Hollandi jaamu 675 kHz R. Calypso ja 1395 kHz-l R. Seabreeze-nemad siis dominandina aga mingil momendil võib samadel sagedustel levi tahtel kerkida aga ka teisi Hollandi low power jaamu.
          ​​​​​​Praha ligidal on R. Dechovka käivitamas 10 kW - st 1260 kHz-l saatjat. Praegu on signaal väga nõrk ja kostab ferriidiga asendit sättides, paralleelsagedus 792 kHz siis väga tugev ja kostab pimedas alati. Sagedusel on veel Saudi Araabia raadio programm.
            Tiraspoli Radio 1+ hommikune 621 kHz-i saateblokk koliti augustis uuele ajale 15.00-18.15. Praegusel ajal hakkab meie kandis kostma peale 17.00-st.
            Samalt sageduselt siis ka 21.30-22.30 TWR vene keelne saade, millist varem edastati 999 kHz-l.
            viimati muutis kasutaja swl; 18 October 2022, 18:19.
              Prantslaste RTL Radio (M6 Group) lõpetab uuest aastast pikklainel tegutsemise. Saatja Luksemburgis Beidweileris. Hoitakse kokku 6 GWh elektrit. Edasi saab kuulata DAB+, FM, digitv raadiokanalina ja äpis.
                Seega siis viimane 4-st Euroopas asuvast võimsast pikklaine saatjast prantsuse keeleruumi lülitakse välja. Esimene oli RFI, siis RMC ja Europe1.
                Pimedas siiski 153, 198, 225 ja 252 kHz signaalid olemas, lisaks veel hõreda saatekavaga 243 kHz.
                Parandan eespool tehtud vea - 621 kHz TWR saade on eetris 20.30-21.30.
                Nii nädalat 2 on Bolshakovo saatekeskusest tehtud paaritunniseid teste 1143 kHz 150 kW saatjaga.
                Praegu edastas R. Rossii programmi ja lülitati välja 18.45.
                Kirjutatakse,et novembri algusest peaks käivituma ka 1089 kHz-i saatja staniitsa Tbilisskajast.
                  B22 hooaja sagedusi vene keelsete saadetega
                  Türgi TRT 16-17 9410 kHz ja RRI 16-17 11630 kHz
                  Kirjutatakse, et aastavahetusel kavatseb Slovakkia loobuda kesklaine edastusest, seega 702 ja 1098 kHz.
                  Slovakkia programm on selle poolest eriline, et edastab siinkandis vist ainsana klassikalist muusikat kesklainel.
                    Kirjutavad, et
                    Second one is from the Radio Andorra archives. 90 minutes with Serge
                    Gainsbourg. Saturday, 5th November 1700-1830 UTC on 6180 kHz via
                    ORS Moosbrunn towards Europe 270 degrees with 100kW
                    Peaks siis kella 19.00-st sealt Austria kandist kostma.
                    Täna on SWR Virra eetris, levi ei ole kuigi hea aga praegu 6170 kHz-l kostab koos mingi kaugema signaaliga.
                    Ajuti on hommikusel ajal 720 kHz-l kuulda BBC 4 signaali Muidu on seal tavaliselt Aktualitate. BBC 4 - l on 720-l Ulsteri regioonis 3 saatjaga ühislaine võrk ja teatud leviga seda on kuulda.
                    Viimasel ajal on vist Djibouti 1431kHz saatja võimsust vähendatud. Kui see VOA signaal kostab tugevamalt, kui tavaliselt, siis tasub kuulatada ka 1539 kHz-i sagedust-seal on Djibouti oma riigiraadio. Mingi aeg tagasi sattusin kuulma, seal edastatakse äratuntavalt nn. Aafrika sarve kandi muusikat.
                      Eilsest on Tiraspoli Majak saatekeskus eetris ainult 1413 kHz saatjaga. Teised sagedused - 621, 999 ja 1548 kHz on vakka . Ei jätkuvat energiat.
                      Moldaavia Raadio edastab õhtu jooksul 873 ja 1494 kHz-l õhtu jooksul ka paar korda vene keelseid uudiseid. Sealt ka võib midagi teada saada mis neil energeetikas toimub.
                      Samas praegu kostab 999 kHz-l lisaks COPE - le //1296 ka Orzu (Tadzikistan) saatja R. Afganistan International programmiga //7600 kHz.
                      Twentelased märkasid lisaks 4625 kHz signaalile ka 4612 kHz-l samasuguse.
                        RNZI on teinud mingeid võimsuse ja edastus mahu kärpeid, lisaks veel osa edastusest DRM-is. Ka saade meie aja järgi 15.00-18.50 peaks mingitel andmetel olema digitaalne, kuid praegu 15.15 kostab tugevalt 7390 kHz-l ikka telefoni resiimis.
                        Majaki objektile siiski leiti natuke energiat ja seega R. Rossii kella 20.00 - 00.00 - ni 999 kHz-l poole võhmaga.
                        Õhtul 20.00-21.00 KBS vene k. saade tugeva signaaliga. Vist Woofertonist.
                          Kuulen, et kostab 9610 kHz-l RRI kõll ja seejärel hiina k. - RRI Bukarest edastab 15.30-16.00 hiina k. //11825 kHz-l tugevalt.Eksootika missugune.
                          ​​​​​​Taibei saade kodusaatjast 13.00-14.00 9490 kHz Siberile. Kuulda keskmise tugevusega.
                          KBS Seoul kodusaatjast Siberi suunas15.00 - 16.00 9645 k Hz, kuulda nõrgalt. See signaal rändab siia poole rohkem põhja poolt, seega on tema levitrass ebasoodsam aga ta võib olla lihtsalt huvitavaks levi majakaks Kaug-Ida trassil-soodsa leviga on kuuldavus parem.
                            Selline video RTL France 234 kHz saatja ajaloost https://www.youtube.com/watch?v=k0pnRdijkzg
                            Siin ajakohane nimekiri Hollandi erajaamadest
                            De LPAM Middengolf zenderoverzicht, Middengolf Radio, AM, LPAM Radiostations, AM 675 kHz, AM 747 kHz, AM 1008 kHz, Radio Babylona, LPAM, middengolf, middengolfzender, overzicht LPAM, LPAM Radiostations, Middengolf Radio, LPAM Overzicht, AM, 675, 747, 801, 819, 828, 846, 891, 900, 918, 1008, 1035, 1098, 1116, 1134, 1179, 1224, 1251, 1287, 1332, 1395, 1467, 1485, 1557, 1566, 1584 en 1602 kHz.
                            Kuigi 1566 kHz-i Vahoni edastamisest loobuti juba varem. Nende saatja oli ka kusagil 1 kW ringis, seega mitte tavalise hobiraadio kategooriast.
                            R. Absolut (1215 kHz) kavatseb loobuda 20. jaanuari paiku kesklaine saatjate kasutamisest. Kuulajatest olevat AM-is 2% aga edastus kuludest võtvat 34 %.
                              Praegu õhtul kuulda 1215 kHz-l WT majakas ja parema leviga ka üks Saudide saatja.1098 kHz - l ferriidiga kuulates poleks nagu midagi, kuigi seal peab olema üks Hispaania erajaamadest.
                              Praegusel aastaajal on kesklaine kuuldavus kehvapoolne aga kevade poole liikudes asi hakkab paranema. Üle 100 kW saatjad siiski kuuldavad.
                              Tbilisskajas lülitati 48 tunniks sisse 1089 kHz saatja võimsusega 1200 kW, edastab praegu R. Sputnik programmi.
                              Kuulda oli signaali juba enne 16.00. Praegu kostab segamini Talksport-i (sagedusel 6 saatjat) programmiga aga ferriitantenniga kuulates on võimalik mingil määral emba-kumba välja peilida.
                                Rip
