Müüa Naim Supernait 2
Hind:1899.-
Asukoht Tartu.
Kaasa pult, voolu kaabel, manual.
– 80W per channel power output
– Six individually decoupled and hand-wired inputs with support for both DIN and RCA connections
– Built in Naim Audio DR (Discrete Regulator) power supply for preamplifier section
– 1/4” (6.35mm) headphone output and high quality class-A headphone amplifier
– Ceramic heat sink isolation for improved sound quality on power and preamp sections
– Dedicated subwoofer output
– Powered input for use with StageLine or SuperLine phono stage
Audio Outputs
Audio Outputs: Speakers, record, preamp and variable sub
Other Outputs: Headphone, 1/4″ jack
Line Outputs Variable (level): 775mV, <50Ω
Line Outputs Fixed (level): 130mV, 600Ω
Power Outputs: Naim phono amplifier
User Control
Front Panel: Volume Control, Balance Control, seven button matrix
Connectivity
Updates: 1 x USB Type Mini-B
Remote Input: 1 x 3.5mm jack on rear (RC5 modulated/unmodulated)
Speaker Outputs
Power Output: 80W/channel, 8Ω
Finish
Case: Black powder coated
Front: Brushed and black anodised
Hind:1899.-
Asukoht Tartu.
Audio Outputs
User Control
Connectivity
Speaker Outputs
Finish
